Magnusson sc on 14 tundra?
Discussion in 'Performance and Tuning' started by kingranch, Aug 22, 2023.
  1. Aug 22, 2023 at 11:01 AM
    kingranch
    kingranch [OP] New Member
    So I purchased a 2014 trd w Magnusson SC
    It has a bullydog tuner plugged into the obd.
    My question is is the tuner telling the ecm to run at the different air/fuel or is it reflashed ecm.
    I guess I mean is if I unplug the bd will it still run ok?
    I am just preparing myself for future repairs etc as I want to understand how my truck runs so I can know where to look for problems etc.
  2. Aug 22, 2023 at 11:15 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Is it a bullydog GT? You can remove the display with no issues. You also can look to see what canned tune has been flashed to your ecm on the bd. The 2014 you will have the Toyota flashed ecm for the SC and usually the 93 tune from BD.
  3. Aug 22, 2023 at 11:42 AM
    kingranch
    Yes it's a GT
    I was curious how the truck gets its tune if it was through the ecm or the bullydog
  4. Aug 22, 2023 at 12:13 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I recommend getting a new tune.
    HulkSmurf14 and Mdl like this.
  5. Aug 22, 2023 at 12:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The canned tune from BD will show on the unit itself. It is flashed to your ecm.
    I second removing the BD flash from your ecm and getting a proper tune. You should still have the Toyota flashed ecm. Is there a SD card installed in the unit? The BD Should show your VIN that has the tune on it.
    I have the GT but removed it as it is a poorly written tune. You can contact BD and their support can walk you through restoring the Toyota SC flash to the ecm.
    *Wanted to add that the tune may be fine for your application. The issue with BD is running other modifications beyond just the SC and exhaust.
    Saltyhero13 and reywcms like this.
  6. Aug 22, 2023 at 5:26 PM
    kingranch
    It runs like a raped ape... I don't want to change a thing
    I believe it was dyno tuned at the shop that installed it also
    reywcms likes this.
  7. Aug 22, 2023 at 5:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok then...to answer the original question. You don't need it plugged in. It is flashed to your ecm.
