Magnuson supercharger issue
Discussion in 'Performance and Tuning' started by Duneflyer, Feb 21, 2020.
  1. Feb 21, 2020 at 3:46 PM
    Duneflyer
    Duneflyer [OP] MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Hey guys, sounds like my supercharger is having an issue. At idle both in park as well as in gear, I hear what sounds like a bearing issue. The noise is coming from the top center front just above the pulley about 6 inches.. on the supercharger. Any of you have an issue like this? If so, how easy is the fix? Where do the parts come from, though I would assume it would be Magnuson. There is no power difference noticeably anyway. But I don't want to be driving along and have my supercharger go out.
  2. Feb 21, 2020 at 4:57 PM
    TXTundra2722
    2015 Black Tundra
    How many miles on the truck with the supercharger? Yes there is a rebuild kit for the charger
  3. Feb 21, 2020 at 5:04 PM
    Duneflyer
    Darren
    Yuma AZ
    Unfortunately only about 7k. Unfortunately the original blanket tune from bully dog was not a good one for my truck and the extra bolt ons I already had on the Truck and had nothing but issues with it. It makes me think it caused issues.
    I am now running OVTune and has been great.
    HulkSmurf14 likes this.
  4. Feb 21, 2020 at 5:27 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Bad coupler?
    If you are on Facebook, join the Supercharged Tundras page. Post there. You'll have an answer within a few minutes. Also, might not hurt to have audio/video of it when you post.
    https://www.magnusonsuperchargers.c...-257_RevA_Tundra_5.7L_Coupler_Replacement.pdf
    Also, if it is the coupler there is a specific one to buy and a bad one NOT to buy. The Facebook group can tell you which one is which and where to buy.
    RitcheyRch likes this.
  5. Feb 21, 2020 at 6:04 PM
    Nick T
    Nick T New Member
    Nick
    Does it sound like marbles rattling around ?
    As MJoeP said, it is probably your coupler.
    7k miles, have Magnuson warranty it.
  6. Feb 22, 2020 at 8:26 AM
    Duneflyer
    Darren
    Yuma AZ
    yep.. marbles...
  7. Feb 22, 2020 at 8:45 AM
    Duneflyer
    Darren
    Yuma AZ
  8. Feb 22, 2020 at 8:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @T-Rex266
    Duneflyer[QUOTED][OP] likes this.
  9. Feb 22, 2020 at 8:54 AM
    Duneflyer
    Darren
    Yuma AZ
    Thanks for the heads up on the FB page. I have applied for membership and am awaiting approval.
  10. Feb 22, 2020 at 9:08 AM
    Nick T
    Nick T New Member
    Nick
    It is your coupler. The nose cone needs to come off.. to access the lower bolts on the cone, you need to either by lift the supercharger or remove the coolant crossover pipe underneath the cone.
    Lots of guys reccomend the Jon bond coupler...I changed mine with the OEM magnuson coupler, which comes with the oring gaskets and new nose cone bolts. As you only have 7k miles on your charger, it should be a warranty repair... not sure if they warranty the labor but that parts should be.
  11. Feb 22, 2020 at 9:12 AM
    Duneflyer
    Darren
    Yuma AZ
    Thanks for the confirmation. I have send an email to Magnuson this morning about it. So hopefully they will get back with me this coming week.
  12. Feb 22, 2020 at 11:17 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Definitely a coupler. Not terribly difficult to fix.
  13. Feb 24, 2020 at 7:26 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Not true. With some ujoints you can pretty easily remove the nose cone without lifting the blower or removing the crossover.
    My blower had the same issue when I bought it. It's pretty easy to swap the coupler and you don't need to undo anything except the pcv hose as I recall.
    RitcheyRch and Duneflyer[OP] like this.
  14. Aug 18, 2020 at 7:21 AM
    TXTundraSC
    TXTundraSC New Member
    College Station, Tx
    2011 Tundra Platinum 4x4 s/c
    Magnuson S/C, trd exhaust, trd rear sway bar, trd front sway bar, toytec 2.5” level, debadged, toyo r/t 305/55r20
    @snivilous do you have any pics of how you removed the nose cone without removing everything else? Not familiar with what u-joints are in regards to this repair
  15. Aug 18, 2020 at 7:46 AM
    snivilous
    SW UT
    Sadly I do not, from memory the bottom two bolts that are more on the inside were the biggest pain, and I think the passenger side needed one ujoint and the drivers side maybe needed two. It was one of those things of sitting with 3 different length sockets, 3 different extensions, and some u joints and combining them in various ways until I could just sneak around everything. Once I got the combination right it was pretty easy, but I don't have any photos of that combination and it was awhile ago I did it too. I guess you can take comfort in the idea it IS possible without removing the blower, assuming you have the right combination of adapters and lengths lol :D
  16. Aug 18, 2020 at 9:03 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    @TXTundraSC These are u-joints that make getting around things possible
    TXTundraSC and snivilous like this.
  17. Aug 18, 2020 at 9:18 AM
    snivilous
    SW UT
    Oh good call, I missed that part :D
    Mater[QUOTED] and TXTundraSC like this.
  18. Aug 18, 2020 at 9:30 AM
    TXTundraSC
    College Station, Tx
    Thanks fellas, really feel like I can tackle this myself. Just don’t want to pay someone to remove the whole supercharger when they will most likely take the same shortcut and charge me full pop
  19. Aug 18, 2020 at 9:59 AM
    snivilous
    SW UT
    It's more about dexterity and patience to reach the bottom bolts. Removing/rotating the nose of the blower up imo would be just as much if not more so of a pain in the ass since the bolts that hold it down are horrible to reach. At least the snout bolts you can use a ratchet once everything is lined up, the main blower bolts can only be turned like 1/8 turn at a time with a normal wrench.
    Mater likes this.
  20. Aug 18, 2020 at 10:41 AM
    I had the same. Toyota tried putting a nose cone on it- nope. Ended up needing an entire rebuild.
  21. Aug 18, 2020 at 10:45 AM
    timsp8
    NY
    My TRD supercharger went through 3 couplers. Kept getting the rattling after about 6 months. Called Jon bond and he said to send it in for a rebuild. I traded the truck in before that.
  22. Mar 24, 2022 at 1:32 AM
    1Ndone
    1Ndone New Member
    2016 tundra not stock, 4K miles a yr
    magnuson, 2” lift, katzkin interior, ceramic tint, auto start, viper, wheels & tires.
    Nick T said it. You need to remove the coolant crossover or lift the supercharger.
    I just completed a coupler replacement on a 2016 5.7 Tundra under the overhang building shade, on an island. Yes, thats right. Nobody in HI would touch it. Before I moved from CO, I offered a “performance shop” 1k to replace and no return call. Why everyone so scared.
    All excuses on the island from dealers and independent shops and im not a mechanic.
    10 hours total start to finish but 1 hour was making a tool to reach the lower right hex nose cone bolt (you dont need to make this when removing the crossover) . 1 hour was trying to get the nosecone out without lifting the supercharger or taking the coolant crossover off as suggested by someone. No way, no how, but maybe that guy who said this had a different engine size or year.
    The magnuson replacement page is ok to see the set up but they also show the belt tensioner moving the wrong way with an arrow. It moves from driver-side to passenger-side with a breaker bar.
    I chose to take the coolant crossover off. Best way is to take the belt off and then remove the fan and shroud to access more (4 nuts & 2 top bolts). Drop the skid plate 5-8 bolts depending how many toyota lost doing oil changes, drain a pitcher of coolant out and save (valve on driver side) Remove the idler pulley to access nuts on the coolant crossover.
    I bought tools to do this and you will use 1/4,3/8,1/2 in this set.
    Lowes- Craftsman 216 piece set $200.
    Craftsman 4pc pick set (must have to get the coupler out). Metric socketed long allen set (you will only use the #6 on the nose cone and the belt tensioner+ adapt it for a breaker bar. Scary but go slow)
    Homedepot- huskey drive tool set 19pc extensions $50 (you will use almost all these), 3 pc set- plier, needle nose, side cutter. cheap white rubber mallet , huskey allen set metric. Mini bright led flashlight, cheap mini step 12” tall in the cleaning isle to stand on and do work.
    Autozone- simple 1/2 breaker bar. extra long double joint needle nose pliers, extension magnet,mini lithium grease tube.
    This is a big puzzle but its doable if you have some auto knowledge.
    Take many pics as you go for routing hoses and reference later. Also remember to take a pic of the bottom snout cover with the stamped magnuson number for reference later if needed.
    All gaskets and seals were reused and looking very clean at 21k miles on the truck. Magnuson only sent me a tan colored replacement coupler. Wow huh.
    I found this forum, a magnuson replacement chart and also a breakdown in depth on part names and pics on toyota parts deal. https://www.toyotapartsdeal.com/res...PD/my14 tundra 3ur 5 7l supercharger isse.pdf
    Take your time and hawaiian music optional.
    TXTundra2722, bensky and 1eyedclyde like this.
  23. Mar 24, 2022 at 1:49 AM
    1Ndone
    1Ndone New Member
  24. Jan 3, 2023 at 5:30 AM
    adverik
    adverik New Member
    Erik
    2011 tundra trd supercharger
    Hello question for those who have replaced the coupler,
    Went to replace mine went the coupler removal method do to slight noise at idle. Took about 8hrs taking my time, biggest pita was removing actual coupler from supercharger side seemed to be rusted on pretty well. When replacing I noticed where the coupler mounts on the supercharger side seemed to have a bit of play in it is this normal ? Worried it may be rebuild time but I hope not? Also whats with all the rust on the couplers? Does anyone know what causes this? seems normal from everyones pics...
  25. Jan 3, 2023 at 6:10 AM
    timsp8
    NY
    I’d say the rust is probably just from condensation. Has your truck sat for a few days at a time?
  26. Jan 4, 2023 at 6:21 AM
    adverik
    adverik New Member
    Erik
    Yes it has sat from time to time. How about the shaft where the coupler mounts (supercharger side not nose cone side) did you notice any play in yours when replacing it?
  27. Jan 4, 2023 at 6:26 AM
    adverik
    adverik New Member
    Erik
    reywcms likes this.
  28. Jan 4, 2023 at 8:08 AM
    timsp8
    NY
    I didn’t replace the coupler myself, but I went through 3 over about 6-7 years of have a TRD SC on my 2010. There are rebuild kits for these SCs if you think yours if getting worn out.
  29. Jan 6, 2023 at 3:51 AM
    timsp8
    NY
