Magnaflow, flowmasters American thunder, or BAM Exhaust.
Discussion in 'Performance and Tuning' started by Ubc2361, Jan 23, 2016.
  1. Jan 23, 2016 at 8:19 PM
    Ubc2361
    Ubc2361 [OP] New Member
    Tony
    Los Angeles
    Tundra crewmax 5.7 4x4
    Ok guys I really value your guys input, I'm n bout to put exhast in my truck but can't decide on which one. Im leaning towards that flowmasters.
  2. Jan 23, 2016 at 8:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Jan 24, 2016 at 12:04 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  4. Jan 24, 2016 at 4:47 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Definitely BAMuffler. I have yet to hear a negative review on his kits.
  5. Jan 24, 2016 at 6:15 AM
    Bigfx
    Bigfx New Member
    They all will drone just be prepared for that there isn't a system that won't. Even the trd system drones if you have kids are noise sensitive wife they will hate it.
  6. Jan 24, 2016 at 7:12 AM
    Ubc2361
    Tony
    Los Angeles
  7. Jan 24, 2016 at 7:14 AM
    Ubc2361
    Tony
    Los Angeles
    Two kids and wife already hates my truck, pay more attention to truck then her
    Black Wolf and T-Rex266 like this.
  8. Jan 24, 2016 at 11:52 AM
    Ubc2361
    Tony
    Los Angeles
  9. Jan 24, 2016 at 12:09 PM
    Cherry bombs are cool but your neighbors might not think so. :rofl:
    Ubc2361[OP] likes this.
  10. Jan 24, 2016 at 2:59 PM
    csuviper
    Broomfield, CO
    Check out BAMufflers. I have the 6". Can always hear it. Loud when you get on it. Some drone but not bad. Haven't added the hermoltz resonator yet that is supposed to eliminate drone.
  11. Jan 24, 2016 at 3:56 PM
    Ubc2361
    Tony
    Los Angeles
    Supposedly corsa sport eliminates all drone anyone has this set up?
  12. Jan 24, 2016 at 4:17 PM
    A lot of the high end aftermarket exhausts claim little to no drone. Not sure how true that is. The BAM Hemholtz should work quite well since it's cut to the correct length to cancel out resonance. ie:drone
  13. Jan 24, 2016 at 4:48 PM
    treborh 1941
    treborh 1941 New Member
    Tundra 5.7 V8
    Stock from factory
    Go ahead and put Walker Torpedo type fiberglass mufflers on it. It will have a great sound and also be comfortable to listen to at different speeds. Not loud till you put your foot in the throttle system. Its always been that way with Walker Fiberglass mufflers torpedo type.
  14. Jan 25, 2016 at 4:46 PM
    Airbagged
    Airbagged New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    I personally have the single tip Magnaflow and really like it.
    Keep in mind too, that true dual will cause you to loose a small amount of low end torque. I use my truck mainly for towing so loosing any torque was not an option.
  15. Jan 26, 2016 at 6:37 AM
  16. Feb 7, 2016 at 12:47 AM
    Tracker
    Tracker New Member
    Shane
  17. Feb 7, 2016 at 12:52 AM
    Tracker
    Tracker New Member
    Shane
  18. Feb 7, 2016 at 11:13 AM
    prowolf1
    prowolf1 New Member
    2015 Toyota Tundra SR5 5.7
    Flowmaster Super 44, Spyder Auto headlights , spyder auto tailights.
    I'm saying get either a Flowmaster Super 44, amazing sound, or get a super 10 if you want it to be pretty loud, Super 44 is more deep toned and its pretty loud but the super 10 is more towards loud then deep toned
  19. Feb 7, 2016 at 1:00 PM
    HeyWatchThis
    HeyWatchThis New Member
    Tennessee
    2016 TRD Off Road Limited
    Fuel Lethal 20x10 wheels, Nitto A/T Terra Grappler G2 285-55-20, 3" ToyTec lift, fender flares, Predator nerf bars, Linex bed liner, dueled out Flowmaster 50 with black tips.
    I just got mine dueled out with a Flowmaster 50. Sounds great but there is certainly a drone in the middle of top gear.
