Magnaflow 18” fitment on ‘07
Discussion in 'Performance and Tuning' started by Red Sonja, Apr 19, 2021.
  1. Apr 19, 2021 at 3:59 PM
    Red Sonja
    Red Sonja [OP] Mock Warrior
    Ben
    2007 Salsa Tundra LTD
    Bilstein 5100’s at top setting Eibach rears with Toytec 1.5” lift shackles 285/60 R20 Firestone Destination X/T 1.25” Spidertrax Spacers Custom 18” Magnaflow Exhaust(side middle exit) Vland LED headlights
    I’m welding up a cat-back system and need to find a way to adapt intermediate pipes to the 4” on-center inlets of the magnaflow from the 6.5” of the original muffler. I’m curious to see how others have solved this. Is it necessary or can I go straight from the muffler?
  2. Apr 21, 2021 at 6:38 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I'm no expert.....
    Can you return the muffler and get a single center inlet and then use a Y to merge the 2 stock pipes into the single inlet muffler.
  3. Apr 21, 2021 at 7:14 AM
    Red Sonja
    Ben
    Thanks for responding! It’s definitely possible but I think I can angle and weld with the lap fitting to achieve the spacing necessary. The pipes won’t be parallel but I’m not showing the truck. I currently have a bunch of exhaust leaks and this will sort it out. I think I’ll do a little photo story of the assembly incase it could help anyone out. Provided I can do it correctly! HA!!!
  4. Apr 21, 2021 at 7:30 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Good luck.
    I look forward to seeing the finished result.
    Sound clips are great too.:thumbsup:
  5. Apr 21, 2021 at 10:32 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Good luck on your project. I have had magnaflow mufflers on a few different vehicles. They are pretty quiet, do have some decent sound when you step on it, but they did drone a lot more than other performance exhausts/mufflers I have used.
  6. Apr 21, 2021 at 11:42 AM
    Red Sonja
    Ben
    Thanks for the heads up! I’m hoping that this 5x8x18 muffler won’t drone too bad. Don’t have much reference since I was commuting with a Prius for 5 yrs before I got this truck last August. I feel like anything I do will be better than what I have now. Not only is the oem muffler leaking at all of the hangers, here’s what the intermediate flanges look like.
  7. Apr 21, 2021 at 11:51 AM
    frichco228
    Yep, time to dump that. If the drone gets too bad you can check with dirtydeeds and they can set you up with a resonator to fix the drone. Magaflow does have good quality so will be much better than that rusty hunk for sure.
  8. Apr 21, 2021 at 12:01 PM
    Red Sonja
    Ben
    Cool! Gonna try to chop up/clean up the pipe to the back and make it exit behind the passenger side running board. I do the welding so it’s a fun experiment. Gonna just do a turn down until I figure out the geometry. I love doing this stuff. I really appreciate the input!!!
  9. May 29, 2021 at 7:59 AM
    Red Sonja
    Ben
    Finally finished my new exhaust. All 409 stainless and all welding was done with TIG and 308 filler rod. Dynomax intemediate pipes directly in to Magnaflow 5x8x18 muffler. I used beefier 1/2 SS fasteners for flanges. Had to ream bolt holes and gaskets. I used Walker 2.5” lap joint band clamps to secure inlets to intermediates. I had spare 1/2” 304 stainless rod and fabricated a large hanger bracket for the back of the muffler to use existing hanger. I then cut the elbow out of the old tailpipe and positioned it and welded directly to the muffler with a new 45 degree Dynomax 2.5” tube to clear the leaf spring and exit behind the running board. It sounds awesome and no drone!!! I will have to put the baby’s car seat on the driver’s side though.
    ZiaTundra likes this.
  10. May 29, 2021 at 8:15 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Nice work on that diy job!!!
    Red Sonja[OP] likes this.
  11. May 31, 2021 at 5:25 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Good job, welds look good to :thumbsup:
  12. May 31, 2021 at 6:46 PM
    ZiaTundra
    ZiaTundra New Member
    Dang! Nice work
