MAF sensor and throttle body Cleaning
Discussion in 'General Tundra Discussion' started by Matty4wd, May 26, 2018.
  1. May 26, 2018 at 7:47 AM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Is there an alternative to cleaning the maf sensor and throttle body without buying a specific spray?
  2. May 26, 2018 at 12:08 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  3. May 26, 2018 at 12:10 PM
    I bought those CRC sprays from Autozone one for MAF and one for Throttle body, just did two weeks ago no issues or lights
    15whtrd likes this.
  4. May 26, 2018 at 12:11 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Not that I know of and I wouldn't risk using anything but the correct spray
    15whtrd and Matty4wd[OP] like this.
  5. May 26, 2018 at 12:13 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    This may be a stupid question but “do they make spray specifically for a MAF?”
    Pudge[QUOTED] likes this.
  6. May 26, 2018 at 12:13 PM
    Yes
    15whtrd and Pudge like this.
  7. May 26, 2018 at 12:15 PM
    Pudge
    CT
    This^
  8. May 26, 2018 at 12:17 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    WHat’s it called? MAF sensor cleaner? Can you get at any auto parts store? Sorry but I’ve never cleaned mine. I guess I should look at the manual to see how often I need to do this.
    Matty4wd[OP] and Pudge like this.
  9. May 26, 2018 at 12:19 PM
    Pudge
    CT
    Yup that's the stuff, Idk how often to use it either. I did my tacoma after 60k miles but I don't remember why
  10. May 26, 2018 at 12:20 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks @Pudge
  11. May 26, 2018 at 12:53 PM
    Autozone, Advance AutoParts, Oriellys
    Pudge likes this.
  12. May 26, 2018 at 12:59 PM
    Be sure to disconnect the Neg batt cable, disconnect electrical connection to MAF then two phillips head screws, pull MAF out and follow can directions
    Sunnier and Matty4wd[OP] like this.
  13. May 26, 2018 at 1:01 PM
    For Throttle body, I left on didn't take off, spray on heavy duty paper towel and clean inside and butterfly both sides
    Sunnier, Pudge and Matty4wd[OP] like this.
  14. May 26, 2018 at 1:10 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thank you.
  15. May 26, 2018 at 1:15 PM
    Yes Sir
  16. May 26, 2018 at 2:26 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    THIS ^^^
    I'll add:
    I clean the air filter and MAF with every oil change.
    I have the S&B intake, which requires a little disassemble before cleaning. While at it, I take the extra 5 mins and take the intake tube apart.
    Personally, I just leave the MAF in the intake. I just unplug it after disconnecting the neg. term, as described above.
    FYI, when spraying the MAF cleaner, spray in the direction of the airflow. I usually use about 2-3, 10 sec. blasts.
    I typically see my MPG's improve the days/weeks following as well.
  17. May 26, 2018 at 3:10 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Sounds like ill be doing it with the proper spray, its better that way. Thanks everyone, and as @GAknight said you saw mpg gain- ive also heard it gives faster throttle response? Anything else that will come out of a MAF and tb cleaning?
    Sunnier and Pudge like this.
  18. May 26, 2018 at 4:55 PM
    Pudge
    CT
    How often are you guys doing it? I guess technically not needed unless youre throwing codes but can this be considered preventative maintenance every few oil changes?
    Matty4wd[OP] likes this.
  19. May 26, 2018 at 5:04 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    I would like to know the answer to this too
  20. May 26, 2018 at 6:51 PM
    Like @GAknight said, since him and I run CAI, (Me) I do mine every other oil change
  21. May 28, 2018 at 1:30 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    I do mine every oil change.
    Like I mentioned, I have to disassemble a few pieces when I clean the filter anyway. I take the time to wipe down the airbox and tubes as well. It's just way to easy to unplug the MAF sensor and spray it off. The extra mgps I get (for the next few days at least) are worth my time, IMO.
