Made a oopsie
Discussion in 'General Tundra Discussion' started by Cajun1977, Jan 30, 2022.
  1. Jan 30, 2022 at 7:00 AM
    Cajun1977
    Cajun1977 [OP] New Member
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Level lift Tonneau cover
    Was cutting some zip ties out from under my passenger seat where I had tied up some led lights and wasn’t paying attention and cut through the yellow srs cable on accident. Of course srs warning light is on. It was cut about 10 inches behind the harness. Towards the back. How expensive is this repair/replacement???
  2. Jan 30, 2022 at 7:03 AM
    Wire strippers, inline crimp, heat shrink.
    1.56
    Bakershack, YotaBro, Wynnded and 5 others like this.
  3. Jan 30, 2022 at 7:04 AM
    Taco-Spike
    Two Trucks
    free if you have a soldering gun
  4. Jan 30, 2022 at 7:04 AM
    Cajun1977
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Not sure I can do this with srs. Saw online somewhere a that it’s a real hazard for safety malfunctions. Not sure if that’s correct though.
  5. Jan 30, 2022 at 7:04 AM
    jeman022004
    jeman022004 New Member
    Jeff
    2019 Limited CM TRD Off-road
    Is it not possible to reconnect the wires? Several options for this from soldering to the many types of solder-less connectors. If it is too short, you can just add in a small length of the same gauge wire.
    Taco-Spike likes this.
  6. Jan 30, 2022 at 7:08 AM
    2mchfun
    I would slip a heat shrink on the longer of the ends, strip, braid, solder, shrink. Good as new!
  7. Jan 30, 2022 at 7:10 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Disconnect the battery before repairing!!!!!!!!
    landphil, YotaBro, Darkness and 3 others like this.
  8. Jan 30, 2022 at 7:15 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that this is VERY important! Otherwise it could become expensive and ...uncomfortable.
    GODZILLA and ColoradoTJ like this.
  9. Jan 30, 2022 at 7:20 AM
    Well if he doesn’t, then it will test if his work was of journeyman level. :D
  10. Jan 30, 2022 at 7:21 AM
    You could always call the dealership parts department for a replacement harness. Probably not over a couple hundred dollars. At this point it might be worth it to you for a piece of mind.
  11. Jan 30, 2022 at 7:24 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was just thinking that if somehow a bag deployment was accidentally triggered during repair...that would hurt.
    GODZILLA and ColoradoTJ[QUOTED] like this.
  12. Jan 30, 2022 at 7:25 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Made a oopsie
    Might I recommend the butt splices that feature a ball of solder inside and are covered with a heat-shrinkable jacket?
    You apply heat from a heat gun. Spraynard has enjoyed great success with those.
    Bammer, des2mtn, GODZILLA and 2 others like this.
  13. Jan 30, 2022 at 7:26 AM
    2mchfun
    Passenger seat airbag will not function with an empty seat.
  14. Jan 30, 2022 at 7:26 AM
    The ear would not like it at all. Kinda like a flashbang going off.
    GODZILLA and Wynnded[QUOTED] like this.
  15. Jan 30, 2022 at 7:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Unplug the battery. Disconnect the plug and solder the wires back together. Plug it back in and connect the battery. Should be fine.
    Wynnded likes this.
  16. Jan 30, 2022 at 7:44 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I think there is something about the srs wires(s) that recommend to replace the entire harness - about the resistance being altered with an attempted repair? Not sure how patching the wire could interrupt resistance if you utilize same gauge wire, etc but I guess it’s worth a try. Can’t imagine that an attempted repair would cause anything other than keeping the light on. Just make sure, like others have said, to disconnect the battery first.
    ColoradoTJ likes this.
  17. Jan 30, 2022 at 7:47 AM
    Could be on to something here.
    Call the parts department tomorrow and let us know what you find.
  18. Jan 30, 2022 at 9:32 AM
    Cajun1977
    Shawn
    Northwest Arkansas
    2020 CM TSS
    Thanks guys it’ll probably be a few days till I can get to the dealership
    2mchfun likes this.
