Lunge with low speed braking?
Discussion in '3rd Gen Tundras (2022+)' started by awpk03s, Jun 1, 2024.
  1. Jun 1, 2024 at 8:09 AM
    awpk03s
    awpk03s [OP] New Member
    23 TRD Sport w/8k miles. Notice at low speeds braking, it like will like longer or hop before coming to complete stop. Doesn’t happen every time, seems like mostly notice with low speed in town type driving.
    Anyone else experience this?
  2. Jun 1, 2024 at 1:32 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Make sure it's not the auto start stop kicking in.
    Hard press on brake pedal activates it/soft press will not. Look for a message on the left of the dash.
    Not sure if this has been brought up before as the search function isn't doing so good.
    My past f150 used to do it really bad coming down a hill low speed and it would go hard on acceleration while I was on brakes slightly then I have to really press on the pedal but this only happen a couple of times.
  3. Jun 1, 2024 at 2:11 PM
    awpk03s
    Thanks, I don’t think it’s auto start/stop, as I typically turn that off….
    best described as it feels like going over a bump or something when braking to a stop and rpm’s are 1k and less.
    It’s weird. I do have AFE intakes and Dirty Deeds exhaust, but I can’t see either contributing to this…
  4. Jun 1, 2024 at 2:12 PM
    Breathing Borla
    Northern Illinois
    Do you have the latest recall for the parking brake or trans letting it roll forward , or was that done recently ?
  5. Jun 1, 2024 at 2:17 PM
    awpk03s
    I bought the truck a month ago, dealer said any/all recalls were completed…. I don’t have records of what though. Lookup by VIN doesn’t show any open recalls for it…
  6. Jun 1, 2024 at 2:19 PM
    Breathing Borla
    Northern Illinois
    how many miles on it and has this done this from the start or did it just start doing this ?
  7. Jun 1, 2024 at 2:22 PM
    awpk03s
    8k miles…. I have only really started noticing it. But, it’s like situational based on driving like it’s not every time.
  8. Jun 1, 2024 at 2:44 PM
    Breathing Borla
    Northern Illinois
    It take the trans forever to warm up, so that could be it
    otherwise have you taken off your neg battery cable at all recently ? If so, could be the trans rel learning
  9. Jun 1, 2024 at 2:53 PM
    awpk03s
    Aha, well yes indeed I did disconnect negative battery terminal when I installed the intakes and exhaust, which was about 1-2 weeks ago, and that’s about when I started noticing it
  10. Jun 1, 2024 at 5:14 PM
    Breathing Borla
    Northern Illinois
    ok, what you have is the logic got wiped , drive about 500 miles or so and it will re learn and be smooth as silk
    You can also speed that up with a couple red line runs where safe , I’m not saying break the speed limit
    boost on:burnrubber:
    awpk03s[QUOTED][OP] likes this.
