Lug nuts coming loose
Discussion in 'Wheels & Tires' started by Jcpedro, Jan 22, 2019.
  1. Jan 22, 2019 at 6:40 PM
    Jcpedro
    Jcpedro [OP] New Member
    I have a 2015 tundra with a 6 inch lift and 35’s. The front lugs keep coming loose. I’ve had a tire come completely off. They put new studs and lugs on but now the lugs are coming loose again. Any suggestions or anyone have a similar experience?
  2. Jan 22, 2019 at 6:48 PM
    Torqued properly?
  3. Jan 22, 2019 at 6:50 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    How many threads of engagement (turns) are you getting? What torque spec? Stock or aftermarket wheels? If aftermarket, do you have Extended length lug nuts?
    Stealth Custom Series sells ET lugs at a decent price.
  4. Jan 22, 2019 at 6:50 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Different wheels with wrong type of lug nuts?
    TTund16, 15whtrd and Sas like this.
  5. Jan 22, 2019 at 6:59 PM
    Eugene406
    Eugene406 New Member
    Montana
    2002 Toyota Tundra SR5 TRD
    Bone Stock.
    I second Dan.
  6. Jan 22, 2019 at 7:03 PM
    Jcpedro
    They are aftermarket wheels. All lugs are new and extended length. I’ve had them checked by two different tire shops and everything checked out. Everything is tight for a few weeks and eventually they start loosening. Tighten by hand and with torque wrench but still have the same problem.
  7. Jan 22, 2019 at 7:04 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    What wheels?
  8. Jan 22, 2019 at 7:11 PM
    Jcpedro
    Rims are Baillistic Off road
  9. Jan 22, 2019 at 7:14 PM
    Boudin
    Boudin New Member
    Louisiana
    Tundra#4
    Stud could be bottoming out in the lug if not the right length lug to compensate for the ET. Or could be a difference in lug seat angle between the wheel and lugs. Sure the ET portion of the lug is passing through the hole? Some wheels don't have the clearance for them.
    OBXTundra, TTund16, dandailey and 2 others like this.
  10. Jan 22, 2019 at 7:17 PM
    Jcpedro
    I’m not a car guy so I’m not sure. I took it to two different tire shops that said they on properly but obviously there’s an issue they aren’t catching.
  11. Jan 22, 2019 at 8:21 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    All of the above are good suggestions. Without a pic of the lug nut interfacing surface, lug stud and possibly the wheel off, it's hard to make a call.
    pickeledpigsfeet likes this.
  12. Jan 22, 2019 at 9:51 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Pull a lug nut off and post a pic of the stud and of the lug nut separately.
  13. Jan 22, 2019 at 10:16 PM
    I would be willing to bet the studs were subjected to a rattle gun and over torqued.
    Take a new lug nut, even a new factory lug nut and tread it onto the wheel stud by hand. If this is difficult to thread on, bet that’s the issue.
    Installing new studs is not fun on bearing hubs and semi-floating rear axles.
    equin and 15whtrd like this.
