Lug Nut Torque FT LBs and Spidertrax
Discussion in 'Wheels & Tires' started by 040Tundra, Sep 28, 2017.
  1. Sep 28, 2017 at 9:31 AM
    040Tundra
    040Tundra [OP] Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Hey guys I’ve got a question about Spidertrax and stock lugs.
    The directions for the Spidertrax read that the torque on them is 97 ft lbs. The directions from Spidertrax also reads put your wheels back on your truck with 97 ft lbs of torque on the stock lugs, however the Toyota manual reads that stock lug nuts on the truck be tightened to 154 ft lbs of torque.
    Q: Which ft lbs would be safest, the 97 ft lbs on stock lugs or 154 ft lbs as the manual reads??
    :thumbsup:
  2. Sep 28, 2017 at 9:57 AM
    Oh, your mixing steel wheels and aluminum spacers. I would call Spidertrax and get their advice.
  3. Sep 28, 2017 at 10:07 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Agree with ColoradoTJ.
    154 ft/lbs is for steel wheels and acorn style lugs. If you're using alloy wheels with the regular lugs, then 97 ft/lb should be good.
  4. Sep 28, 2017 at 10:52 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    97, or you risk damaging the aluminum spacer by over torquing.
    MikeyMTBs likes this.
  5. Sep 28, 2017 at 11:02 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'd go with the lower, minimum required.
  6. Sep 28, 2017 at 3:02 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    WHen I did 97 ft lbs of torque it just felt loose, that’s all. I guess I’ll go do it again. Damn it!!
  7. Sep 28, 2017 at 3:27 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Alright @ColoradoTJ I did as you suggested with 97 ft lbs on the Spidertrax and 97 ft lbs on my aluminum wheels to the Spidertrax with stock lug nuts.
    Thank you for your help. I wouldn’t have wanted to damage anything so thank you guys.....:transformer:
    Mountun Goat likes this.
