"Lubricate latches, hinges, and locks"
Discussion in '2.5 Gen Tundras (2014-2021)' started by AndrewSmith, Jan 5, 2022.
  1. Jan 5, 2022 at 4:30 PM
    AndrewSmith
    AndrewSmith [OP] New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    That's from the mainenance schedule. Curiously my wife's Subaru has that exact same line on the maintenance schedule.
    Does anyone actually do that? Or is that just a "cover our ass" item for Toyota?
    If you do: can you please share a list of which latches/hinges you lubricate, how, and with what? If you use some sort of grease: do you worry that dirt will stick to the grease and make it worse instead of better?
    Thanks in advance.
  2. Jan 5, 2022 at 4:41 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    T2ndLife and Dsptundra like this.
  3. Jan 5, 2022 at 5:20 PM
    Big Papi
    Big Papi New Member
    Massachusetts
    2021 Tundra TRD Pro Black
    Door locks with graphite. No one use them till their fob battery dies and then they don't work.
    1lowlife likes this.
  4. Jan 5, 2022 at 5:22 PM
    AndrewSmith
    Thornhill, Ontario
    Do you just spray it in there or is there some technique involved?
  5. Jan 5, 2022 at 5:24 PM
    AndrewSmith
    Thornhill, Ontario
  6. Jan 5, 2022 at 6:01 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Eezox is your friend!!!
    Spray all your hinges and latch mechanisms with it.
    Then spray a bit on your key and insert it into the locks.
    I also spray down my suspension components with it before my off-roading trips.
    https://www.eezox.com/
    coldcanuk and 1lowlife like this.
  7. Jan 5, 2022 at 6:05 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Similar to balistol?
  8. Jan 5, 2022 at 6:07 PM
    Black
    Correct, but Eezox does not smell like a combination of nasty feet and licorice!
    Used to use balistol even with the smell but found Eezox and prefer it because it does not stink and it dries better and does not pick up as much dirt and grime.
  9. Jan 5, 2022 at 7:29 PM
    Big Papi
    Big Papi New Member
    Massachusetts
    I put powdered graphite on the key and insert in and out. I was able to get a lock on my 04' working again that way.
  10. Jan 5, 2022 at 7:33 PM
    T2ndLife
    T2ndLife New Member
    JD
    '02 4.7L 225K 4WD Ext Cab
    WIP - keeping stock Kenwood DNX9960 GPS Nav/Stereo NexD XD400/4 400W Amp Wood Trim package added 4Runner alloy 17 inch wheels
    Ditto on the litho grease for hinges for my olde '02... No problems with dirt, cleaned it all first with some WD40 and wipedown.20211204_151648.jpg
    des2mtn likes this.
  11. Jan 5, 2022 at 7:56 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    I used to use fluid film and/or white lithium grease but found that looked nasty quickly and built up all sorts of crud which tweaked my ocd and also gummed stuff up (ie the tailgate latches). I switched to teflon based dry lube a few years back, sprays on and the propellent/carrier fluid evaporates leaving the dry lube and binder behind. Everything stays nice and clean, no thickening in cold weather and functions well even in very cold temps. Personally I’d never go back to a grease or oil based lube now. Quick lap around the truck while the oil is draining at each fluid change and right by the garage fridge too- win-win.
  12. Jan 5, 2022 at 11:15 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ I like this.
    I hated the smell of Ballistol..
    Gave it away on the gun forum I used to frequent.
    The Froglube I tried smelled better..:D
    To anyone reading this, go ahead and lube your house door locks and hinges..
    Barrett50 likes this.
  13. Jan 5, 2022 at 11:59 PM
    Black
    Sigforum??
    Kung likes this.
  14. Jan 6, 2022 at 5:10 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    You missed this spot, that is where most of the wear and friction comes from the door check.
  15. Jan 6, 2022 at 5:33 AM
    blanchard7684
    blanchard7684 New Member
    Timely thread.
    This is an aspect of vehicle maintenance I need to get better at.
    MadMaxCanon likes this.
  16. Jan 6, 2022 at 7:49 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Or XDtalk, I can't remember.
  17. Jan 6, 2022 at 7:55 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Especially on older trucks, cleaning and lubricating moving parts makes a difference.
    Climate control cables, window tracks,you can take apart doors or tailgate and hit the clips for door rods.
  18. Jan 6, 2022 at 8:08 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    I did my hinges with this. For door locks I use a good silicone but they say this stuff is good for that too. On the sunroof a dry lubricant. Honda Shin Etsu grease for the rubber seals, sometimes good old 303
  19. Jan 6, 2022 at 5:12 PM
    Black
    Thought I recognized your handle from Sigforum.
    1lowlife[QUOTED] likes this.
  20. Jan 6, 2022 at 5:33 PM
    AndrewSmith
    Thornhill, Ontario
    Where are the climate control cables? Are they hard to get to?
  21. Jan 6, 2022 at 5:42 PM
    des2mtn
    Shady Grove
    Tonto cover
    I'm in the wrong section, sorry, I have a different truck. But there are moving parts behind my dash that manually control the climate control system and the amount of heat the system gets. I guess my point was more the little things that you wouldn't think of in your truck that move.
  22. Jan 7, 2022 at 8:13 AM
    Crocktopus
    Crocktopus New Member
    Hi all,
    I am new here and actually don't have a Tundra (even though I find it a very tempting truck), but I still wished to add my thoughts.
    I have a 2018 Hyundai and the service schedule DOES include lubricating hinges as well.
    I maintain my car (s) meticulously, after confirming with the dealership not to lose warranty I do my own oil changes as well. Every once in a while, when the service schedule calls for bigger services (400+ CAD by the way), I take it to dealerships to get it done so I can prove the car is indeed being maintained well.
    EVERY SINGLE MAINTENANCE SERVICE where "lubricate latches, hinges and locks" was required, the dealerS (yes, three of them) told me they inspected them and applying more lubrication would have been excessive. I'd like to point out, that the wording in the booklet never mentioned an option to "inspect and lubricate if required"
    As a side note, and to shed light on these "inspections", another story: as checking tire pressures is part of the 400$ inspections, I aired down one tire. Guess if it has been picked up...
    I did check my hinges though and as I have found them in good order and with some lubrication still visible on them, I did not do it myself yet.
    coldcanuk and WFD473 like this.
  23. Jan 8, 2022 at 4:38 AM
    AndrewSmith
    Thornhill, Ontario
    Thanks for sharing that!
  24. Jan 9, 2022 at 12:21 PM
    fmscott2
    fmscott2 New Member
    I use lithium grease spray for the door hinges and silicone spray for my window guides. Just spray a little where the window meets the rubber trim and it helps the windows slide nice and easy. Any rotating parts that squeak also get a shot of lube.
  25. Jan 9, 2022 at 12:29 PM
    biebs96
    PA
    I use dry spray lube on the hinges, door strikers, tailgate latches, window tracks and spare tire assembly twice a year to all my vehicles.
    The quality I like most about this is that it is invisible and does not collect dust.
    splitfuse, Big Papi and FortyNorth like this.
