LT275/65r20 on stock 2020 Tundra 4x4
Discussion in 'General Tundra Discussion' started by dbrown803, Mar 5, 2021.
  1. Mar 5, 2021 at 9:30 AM
    dbrown803
    dbrown803 [OP] New Member
    2020 Tundra Limited 4x4
    Color matched bumpers front and back.
    I read a bit of back and forth on here and ended up trying it out. Completely stock 2020 4x4 Limited Tundra. 275/65r20 tires with 0 rubbing. All I had to do was remove the front mini mud flaps (2 screws).
    Noeyes and JerryH like this.
  2. Mar 5, 2021 at 9:39 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Looks great! Good to know they fit.
    But it's not "0 rubbing" if the little mini flap rubbed... strictly speaking :rolleyes:
    Still waiting for pics of a 285/60/R20, should be about the same diameter but a little wider
  3. Mar 5, 2021 at 9:43 AM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Truck looks great! Had this same question. Thanks
  4. Mar 5, 2021 at 9:50 AM
    dbrown803
    Touché! The front flaps will go back on, but it’s super close. I went 275/65r20 because that’s the standard size for the 2500/250 series trucks so you can find basically new take offs for super cheap (they usually go up to 35s once they realize it’ll fit). It’s economical or something.
    reneaux likes this.
  5. Mar 9, 2021 at 6:46 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Diameter is about 3/4" lower
