LSPV delete questions
Discussion in '1st Gen Tundras (2000-2006)' started by Jedgar, Sep 15, 2024.
  1. Sep 15, 2024 at 8:32 AM
    Jedgar
    Jedgar [OP] New Member
    2006 SR5 Double Cab 4WD, V8, forest green w/ topper
    None (no lift, don't want one), Bilstein 4600 shocks soon. Bigger Michelin tires soon.
    Questions:
    1. What are the options for a manual proportioning valve to use?
    2. Is there an available valve that the existing steel brake line fittings will screw directly into ?
    3. There is a $75 "kit" of fittings available to use the Wilwood valve. Anything magic about the fittings in the kit?
    4. Where can I buy the fittings to mate between existing steel line ends and the valve, and to plug to return line port into the master cylinder?
    I think I prefer mounting the new manual valve at, or close to, the existing LSPV location. Don't think there will be a lot of adjusting going on once it's set.
    Thanks for your advice. Jim
  2. Sep 15, 2024 at 9:03 AM
    shifty` I'm having daydreams about night things
    noahrexion and KNABORES like this.
