Lsd vs 4wd
Discussion in '2.5 Gen Tundras (2014-2021)' started by Es3045, Nov 28, 2021.
  1. Nov 28, 2021 at 5:22 AM
    Es3045
    Es3045 [OP] New Member
    I live in Michigan this will be my first winter with my 2021 tundra and what works best for slick roads the 4x4 or should I have the LSD on? Thanks
    TundyMcTunra likes this.
  2. Nov 28, 2021 at 6:23 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Good tires and sand in the bed...you will have all the traction you need...if snow ever gets here, I will continue to lower my tire psi and throw 600lbs (x10 60lb bags) of sand in he bed..I only sometimes need 4x4 in regular conditions when weighted. Keep in mind, tires are the ONLY things touching the ground so they need to be good to decent.
    Ely010606, D4x4TRD and Es3045[OP] like this.
  3. Nov 28, 2021 at 6:34 AM
    Wallygator
    If the roads are completely covered I usually run in 4x4. Probably the best thing is to drive sensibly for the conditions presented and have smart control of the skinny pedal. In other words, refrain from making the donuts.
  4. Nov 28, 2021 at 6:39 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    The AutoLSD on these trucks are complete garbage. What a craptastic system. Why they just did not give a true LSD option is beyond me.
    HulkSmurf14 and Es3045[OP] like this.
  5. Nov 28, 2021 at 7:38 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    More weight means longer to slow down. Just something to remember.
  6. Nov 28, 2021 at 7:46 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If it's remotely snowy or icy I just throw it into 4wd and be done. No point in doing tricks to try and make 2wd work when you have 4wd right there. And contrary to some belief, the front diff and tcase will not explode if you drive on dry pavement so even if it's patchy snow and dry I just leave it in 4wd until it's dry enough to not need it. The "LSD" is hard to make work, and weight in the bed I've never had to resort to.
  7. Nov 28, 2021 at 8:01 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    When the snow hits go find one of the many vacant mall parking lots and get a good feel for your truck in 2wd and 4wd. I've NEVER had to put weight in the back to get around just switch it to 4X4 when the roads are ice and snow covered. Besides the heavier you are the more time it takes to stop. When it comes to driving in the snow its 5% vehicle and 95% driver so I recommend getting a good feel for your truck and how it handles. Slam on the breaks, punch it, turn aggressively left and right to the point it breaks loose. Get comfortable with your truck and you'll do just fine. And this...which I can't stress enough...TIRES TIRES TIRES. Get some good tires.
    Now get out there and have some fun OP because at the end of the day that's really what its all about :D
