Lsd traction contol
Discussion in '2nd Gen Tundras (2007-2013)' started by ODSteve, Jun 26, 2014.
  1. Jun 26, 2014 at 7:42 AM
    ODSteve
    ODSteve [OP] New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    When y'alls traction controls kicks in does it make like a grinding sound like err err err err.... Lol?
  2. Jun 26, 2014 at 9:43 AM
    That's ur ABS trying to lock it up...can't stand it. In my experience it makes it more dangerous...I get ABS, but it's too sensitive to wheel spin.
    I can be going a few mph, gently touch the brakes and it wants to lock up b/c it's on ice
  3. Jun 26, 2014 at 9:46 AM
    ODSteve
    Steven
    Well now don't i feel dumb.... So when I'm in the mud and wet roads it's kicking in my abs to Co tool my truck? All I know is it sounds horrible and sucks all the power away haha I forgot to turn it off today leaving location it flooded down here and it kicked In and scared the crap out of me and almost got me stuck haha.
  4. Jun 26, 2014 at 9:00 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Hold the TC button down for 3 seconds until it says auto LSD, rather than just pressing it once. It will shut the traction control off and should work a lot better.
  5. Jun 27, 2014 at 7:51 PM
    ODSteve
    Steven
    I rode in my passager side it's coming from the front right wheel area while braking....:/ gonna have to get it checked I'm on the road to Missouri right now then getting my other truck and heading to upper Michigan.
  6. Jun 27, 2014 at 8:05 PM
    ODSteve
    Steven
    I got out and checked the rotor is fine no scaring or marks can't really see the brake pad. Might be crack or warn weird. It's not pulling are breaking weird.
  7. Jun 27, 2014 at 9:41 PM
    TruckyTruck
    Gary
    It's your computer thinking you are loosing control. Your abs system will go off on whatever wheel it needs to get you under control. And it makes that weird noise. I think if you just press the button once for auto LSD it wouldn't do it because the truck recognizes at that point you are in something you need out of, if it does, you just hold it down for 3 seconds to shut the computers control down most of the way. All toyotas have a distinct abs sound and feel. To me it does anyway. My Camry and Tacoma both were just like that.
  8. Jun 27, 2014 at 10:23 PM
    Can't stand how sensitive they make them.
  9. Jun 28, 2014 at 10:55 AM
    andrew
    andrew where's the beer?
    andrew
    2012 rockwarrior
    stock
    I never knew the three second trick. I'm alot more excited now.
  10. Jun 28, 2014 at 6:22 PM
    TruckyTruck
    Gary
    Didn't know that huh? Well after you hold it down three seconds the computers traction control is off, the LSD is on and the trucks stability control is still on...
    Hold it down 3 more seconds and you shut everything off. Careful now... You might have forgot how to drive on your own!
    ODSteve[OP] likes this.
  11. Jun 28, 2014 at 9:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    He'll yea I want to turn it all off.
    TruckyTruck likes this.
  12. Jun 29, 2014 at 5:36 PM
    andrew
    andrew
    2012 rockwarrior
    stock
    YOLO
  13. Jun 29, 2014 at 5:38 PM
    andrew
    andrew
    2012 rockwarrior
    stock
    What else does it cut off? Abs? I want to cut it off and feel like I'm driving in a time machine.
  14. Jun 29, 2014 at 10:32 PM
    TruckyTruck
    Gary
    Ha, no the abs stay working, but only if you hit the breaks and they try to lock up.
  15. Jun 30, 2014 at 8:19 AM
    csuviper
    Broomfield, CO
    So i did the 3 sec hold down and there wasn't any indication that it did anything different than just pressing it once. No flash of the light or something like that. Hold for 3 seconds again and it just turns the "auto lsd" light off, same as just pressing it once.
  16. Jun 30, 2014 at 10:54 PM
    TruckyTruck
    Gary
  17. Jun 30, 2014 at 11:17 PM
    TruckyTruck
    Gary
    Brian, make sure you are at a complete stop and holding it long enough. If you aren't familiar with the system, read the info in the link I posted above. There is a lot to it.
  18. Jul 1, 2014 at 5:48 AM
    TruckyTruck[QUOTED] likes this.
  19. Dec 12, 2014 at 4:47 PM
    1Yoda2nv
    1Yoda2nv New Member
    2008 Black Tundra TRD
    AFE intake, Corsa Exhaust, Level kit, 20" Monster Energy wheels, 305/55R20 Nitto Terra Grapplers,
    Newbie here but, my tire and alignment shop told me it may just need aligned back to center on the steering wheel. Had them do it and haven't had the problem since?
