LSD or Locker…
Discussion in '2.5 Gen Tundras (2014-2021)' started by Chad D., Dec 30, 2021.
  1. Dec 30, 2021 at 4:59 PM
    Chad D.
    Chad D. [OP] New Member
    Western Oregon
    2018 CrewMax Platinum
    Gents,
    I know this has been beat to death, but I’ll be honest. I struggle with the search feature via my phone…
    The quick rundown:
    I just ordered 5.29’s and will replace my differential when it all goes together. Truck is my daily driver, and primarily street driven. Light off-road use only. I have 34” tires, but am going lower gears because I tow regularly and live in hilly western Oregon.
    I am very familiar with the benefits of a selectable locker, and have used them a ton on my off-road rigs. My thoughts on this truck is that a LSD (Auburn) is going to not provide as much traction as a locker, but should be a substantial improvement over the factory diff. A LSD would, in my mind’s eye, be beneficial every time I get on the throttle because it should limit tire slip. Duh…. A selectable is still an open diff unless I hit the switch, which will likely just be a few times per year when I’m screwing around….
    Thoughts? Anyone use their truck like I do with a LSD and wish they’d gone full bore with an elocker? It’s not the money driving the decision. It’s all about usability and appropriateness for the intended use. Thanks for any input!
    Billybob9 and HulkSmurf14 like this.
  2. Dec 31, 2021 at 6:18 AM
    Chad D.
    Western Oregon
    Oh, I should mention that my biggest LSD concern is the longevity. I drive a solid 25-27K miles per year. I’m expecting to keep this truck as my daily corn another 5-6 years.
    I realize there are about a zillion variables, but how long are people getting out of these things? Replacing it will be a chore…
    HulkSmurf14 likes this.
  3. Dec 31, 2021 at 6:27 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Unless your beating the S%$@ out of it regularly, a decent LSD will last the truck's lifetime.
    To me, lockers are for full time harsh environment running.
  4. Dec 31, 2021 at 7:36 AM
    timsp8
    NY
    I have the Auburn lsd in my current tundra and had it in my 2010 for over 50k miles with no issue. I am thinking of getting the Eaton e locker and regearing soon. I’ve had other trucks with a locker and it was a big difference off road, but I see your point that the lsd would be active all the time.
  5. Dec 31, 2021 at 7:57 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I went with a Powertrax Grip Pro LSD which is gear driven vs the cone washer/clutch setup of the Auburn so theoretically shouldn't wear out, though from my understanding locks up more under torque (so offroading you'd need power to make it do much, but if you're onroad and punch it it'll certainly lock both wheels together) where as an Auburn is always applying the same amount of slip limiting. I don't off-road the tundra to the point a locker would be of any use, but the LSD always being "active" onroad is why I went with it. 5.29s is a lot of torque and easy to break the rear end loose.
    Cfincke, Cruzer and HulkSmurf14 like this.
  6. Dec 31, 2021 at 12:03 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    LSD for your needs without a doubt.
    Though from my reading the PowerTrax seems to be a better unit.
    Biggest downfall of these trucks is the craptastic electronic LSD they should have used true LSDs far more useful.
    snivilous, Cruzer and HulkSmurf14 like this.
  7. Dec 31, 2021 at 12:15 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    LSD for your needs. You don't need a locker and it will cost you $2k (for front and rear), and a little more $ for installation even though they're already in the diff doing the gear, then you'd also need to purchase the air compressor as well. That's at least $2.5k more for something you would rarely use - based on what you stated.
    snivilous likes this.
  8. Dec 31, 2021 at 12:18 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I was just looking into this and the Grip Pro is what I'd consider for identical reasons the OP needs... I'm on tall 33s, use my truck for hauling, and have a light constant load in the bed with a topper plus...and I have a SC'r...one wheel spinning with the OE setup hiccuping all the time is as lame as an electric supercharger...
  9. Dec 31, 2021 at 2:32 PM
    Chad D.
    Western Oregon
    Powertrax, you say? I hadn’t even thought of them, but sure will! I like to idea of non-clutch over the Auburn style.
  10. Dec 31, 2021 at 2:47 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d go LSD. The powertrax is in my future plans. I had an Auburn before and it was decent, gonna try the powertrax next.
  11. Dec 31, 2021 at 2:55 PM
    HulkSmurf14
    2014 Tundra Limited
    1UP and Silver17 like this.
  12. Dec 31, 2021 at 3:09 PM
    Cfincke
    San Antonio
    I have the auburn LSD only because the powertrax kept getting delayed for release in early 2020 and I needed the gears installed before we had a trip towing our camper from san antonio to pencecola.
  13. Jan 1, 2022 at 10:44 AM
    HulkSmurf14
    2014 Tundra Limited
    And...? Has it worked well for you?
  14. Jan 2, 2022 at 12:01 PM
    Chad D.
    Western Oregon
    That would be great as he is a vendor /sponsor here (from what I can tell). Might be worth shopping a little further though. Unfortunately, DD’s advertised price is getting close to 50% more than some other outlets I found in a quick search for the GP501536 model of Grip Pro. I found the same when pricing Nitro Gears.
    Before I get slammed door calling out prices without backup…. Apologies if I am sharing ads for different items. Please correct me if I am, as I do not want to make apples look like oranges!!!
    Grip Pro:
    http://dirtydeedsindustries.com/product/grip-pro-traction-system/
    Powertrax GT501536 Powertrax - Grip PRO Traction System Grip PRO Traction System https://www.amazon.com/dp/B07ZHY99MQ?_encoding=UTF8
    Nitro: $536 difference… In a panic, I called Nitro to see if they have a huge price jump on the firs of the year. The fella I spoke with was unaware of any increase beyond the typical 6% they saw recently. Almost buys the Powertrax….
    http://dirtydeedsindustries.com/product/nitro-front-rear-gear-package-kit
    https://www.justdifferentials.com/Toyota-9-CS-10-5-Nitro-Gear-Package-p/gptundra5.7-xxx.htm
  15. Jan 2, 2022 at 2:06 PM
    timsp8
    NY
    I was looking at gears around Black Friday and DD was $1300. Not sure what happened to make it jump $600 in a month. Even direct from nitro is $1500. Has to be a mistake.
    https://www.nitro-gear.com/Toyota-9-CS-10-5-Nitro-Gear-Package-p/gptundra5.7-xxx.htm
  16. Jan 2, 2022 at 2:18 PM
    Chad D.
    Western Oregon
    I’d sure like to think so, unless his kit is including additional pieces that I didn’t catch. Seems that gears, setup items like shims and crush sleeves, bearings, and seals are the norm. Maybe he’s including enough oil for break in and the second change, as well as who knows what else??? It’ll take a couple hundred bucks worth of oil.
    I did not attempt to call DD to verify. Only a call to Nitro on the 30th to check if all hell was breaking loose on prices. I also saw his Black Friday pricing and agree that this may have been a mistake.
  17. Jan 2, 2022 at 2:20 PM
    Chad D.
    Western Oregon
    Sorry guys. Seems like I’ve hijacked and derailed my own thread here!! Back to the original intent, I’ll be adding a Powertrax Grip Pro to my order this week…. Appreciate the insight from all of you and am glad to find an alternative to a clutch-based LSD.
  18. Jan 2, 2022 at 2:30 PM
    ArdnuT trd
    ArdnuT trd New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    How hard is this to do on your own? No different than my Silverado I assume? I want a true lsd and what gears would you recommend if any for trd bbs pro forged wheels and I'm told 295 is the biggest but I just want a more aggressive than stock at rt tire for my 21 on 6112 at 1.9.
  19. Jan 2, 2022 at 3:48 PM
    Black
    I wonder if DD includes an install kit?
    But if you are surprised at prices on things skyrocketing you have not been paying much attention.
    Falcon leveling kits jumped about $350.
    Slee Slider Steps for the Tundra jumped $400.
    The list goes on.
  20. Jan 2, 2022 at 4:53 PM
    Chad D.
    Western Oregon
    I absolutely understand the recent (15 months in my industry) escalation on material costs, which has a direct effect on retail pricing for the commodities we all love. That is exactly why I reached out to the manufacturer as soon as I saw a big price difference from one retailer. Being told that the price was not going up, to the knowledge of the rep I spoke to, I assumed one of three things are happening with retailers that are advertising prices well above MSRP.
    1. The items included are not the same, as I’d wondered above. Are there more eggs in the basket for this price?
    2. A price update was entered incorrectly on a website.
    3. Retailers are able to set pricing where they like, and can take advantage of the supply /demand balance if they have inventory.
    Any of these are plausible, and would certainly make sense here. If the boxes are packed with different items from different retailers, the price may not be the same. If a price is listed incorrectly, it’s an easy fix. If pricing is being adjusted because a retailer has the advantage of inventory, it happens. It’s up to the consumer to decide if they’re willing to pay extra to have the items now. BTW, I’m looking at March before mine arrive. I’m fine with that.
  21. Jan 2, 2022 at 8:37 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I wish they make lsd for our front diff.
  22. Jan 7, 2022 at 11:42 PM
    Chad D.
    Western Oregon
    Alrighty! Everything is on the way. A close friend owns a local off-road parts manufacturing company and has ordered the Nitro gears with install kits for me at a fantastic price. The downside? Nitro supplier is currently looking at March for delivery…. No biggie. As long as they’re in before June!
    I had him check the Grip Pro, but the best price was Amazon by a significant margin. Lucked out and bought the last one from there yesterday.
    Stay tuned boys. It’s all coming together…
