lowering lifted tundra
Discussion in 'Suspension' started by WolfZ, Sep 22, 2018.
  1. Sep 22, 2018 at 4:43 PM
    WolfZ
    WolfZ [OP] New Member
    hello - just joined the club today when i bought a 2017 tundra.
    it came with a 6" fabtech basic lift. while i love the truck the lift is a little challenging.
    any suggestions for what i can do to lower it?
    the lift has a 6" spacer. would it work if i removed the spacer and just put in an adjustable coilover set at 2"?
    (tires are 35x12.5x20)
    i really just want to lower the ride just a little 2-3" would be great.
    thanks a bunch
    here is a pic of my baby
  2. Sep 22, 2018 at 4:59 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome and Nope! Over 4" of lift requires the cross member be cut out. So, unless you're 2wd you'd have to source the cross member and have it welded back in.
    Black Wolf and BTBAKER like this.
  3. Sep 22, 2018 at 4:59 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The issue will be the front crossmember.
    Best bet is find someone who wants to buy your complete kit and swap their OEM or smaller lift parts to your truck, crossmember included.
  4. Sep 22, 2018 at 5:08 PM
    WolfZ
    thanks guys - i appreciate the speedy responses.
    so what if i'm ok with a 4.5" lift or so.
    if i keep the front cross member cut, can i go from a 6" lift to a 4.5" lift? if so, what do i need to do that?
    (i know it seems silly, but the difference between those two inches is the difference between fitting in to the garage at work vs not)
  5. Sep 22, 2018 at 5:33 PM
    Pudge
    CT
    Yeah man I'd wanna park indoors too. I can't help with the drop to 4.5, I know very little about DB lifts
  6. Sep 22, 2018 at 5:50 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Well after some reading on fabtechs Wes site, I don’t think you can go from their 6 in their 4.5....
  7. Sep 22, 2018 at 5:51 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Though, it looks like you could go to a bds kit....
  8. Sep 22, 2018 at 5:52 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  9. Sep 22, 2018 at 5:56 PM
    WolfZ
    Thegr8punkin[QUOTED] likes this.
  10. Sep 22, 2018 at 6:02 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I think @Jsena has the 7 on his truck,
    Jsena and GNTundra like this.
  11. Sep 22, 2018 at 6:03 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I personally would recommend doing the kit with the coil over but I know the price jumps on it very quickly, but with buying that kit you should be able to recoup to the price of part by selling the fabtech kit
  12. Sep 22, 2018 at 6:09 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    @GNTundra you have a bds loft right Gino?
    GNTundra likes this.
  13. Sep 25, 2018 at 8:17 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yessir gents... Daddy has the BDS 7 . I like it!! No issues with it after 15 months.. I rotate the tires every 4K miles.. I didn’t get the Coilover set up to begin with but I do plan on getting a set... :D:spending:
