Lowering a 06 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by chetsvr6, Dec 15, 2019.
  1. Dec 15, 2019 at 7:37 AM
    chetsvr6
    chetsvr6 [OP] New Member
    Chet
    06 tundra
    None
    Hello guys I just got a 06 tundra. 93000 miles. Can’t find where the timing was changed. When is it due? And I want to lower it 3” front 5”rear. Can’t find a kit. All I can find is a 2/3.5 drop. Any help would be great thank you all
    because_wumbo-truck likes this.
  2. Dec 15, 2019 at 8:07 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Timing belt on the 2uz V8 is every 90K or 6 years.
  3. Dec 15, 2019 at 9:14 AM
    chetsvr6
    Chet
    06 tundra
    None
    Thank you scuba I will check into getting it done
  4. Dec 15, 2019 at 9:31 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    All 4.7's including the early 2nd gen.
  5. Dec 15, 2019 at 9:43 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not a huge deal honestly about $1000 every 100k but that includes new coolant, water pump, belts, tensioners, thermostat, hoses. Could be worse.
  6. Dec 15, 2019 at 9:49 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Was your taco a 4 banger? I thought the 3.4 v6 were a belt?
  7. Dec 15, 2019 at 9:53 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The gen 1 tundra doesn’t have much space between the top of the spring pack and frame in the back. So you’re looking at custom c notch to lower 5 inches. Market is too small for anyone to develop that involved of a kit.
  8. Dec 15, 2019 at 10:03 AM
    FrenchToasty
    Mo
    Bone stock
    It’s a great motor! I HAD it in my 05 taco, plenty of power paired with a 5 speed!
    speedtre likes this.
  9. Dec 15, 2019 at 9:19 PM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    I just purchased another Tundra... 267K miles, ORIGINAL TIMING BELT and all that goes along with it! Previous owner (original) just figured if it broke, she would just buy a new truck... sold it to me (2500.00) because she didn't want to deal with rusted out rear end cover... 05 Access Cab Limited, with Stepside bed. Just did the timing belt friday... it was original... engine had never been opened!
  10. Dec 16, 2019 at 7:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Hmmm, I sense deleted posts...
    Anyways, if you found a kit that does 2/3.5 drop, that's probably what you're stuck with unless you start cutting/welding/fabbing. There's a few vids out there of 1st gens laying frame.
