Lower temps...rougher ride?
Discussion in 'Suspension' started by frichco228, Feb 22, 2020.
Have you noticed a rougher ride when temps get low- low 30s, 20s or lower?
  1. Yes
    15 vote(s)
    88.2%
  2. No
    2 vote(s)
    11.8%
  1. Feb 22, 2020 at 1:45 PM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    We have had a mild winter in Va. Yesterday on my way to work it was somewhere in the high 30s, low 40s. Coming home, low 20s. 2016 CM OR package- stock...and the change in ride going home was enough to notice- a bit rougher for sure.
    I have noticed the same thing on my OME lifted 2006 4runner. Never had it happen when it was stock but those big OME shocks do firm up when it is super cold and the LT tires on it now do not help ride when they are cold.
    Not a huge deal, was just a little surprised. I have never really noticed it happening before on any stock vehicle, only ones where I modified the suspension and used a heavier duty shock.
    Am a dreaming? Or do you notice a ride change with more extreme temperature changes?
  2. Feb 22, 2020 at 3:30 PM
    TTund16
    TTund16 New Member
    Everything gets stiffer when cold like tires, shocks, wheels & bearings, road, etc.
    one of my cars with winter type Michelin tires makes some noise till tires warm-up ... First time I heard the noise I thought something was wrong with the engine. It only does it when in low 20's and lower.
  3. Feb 22, 2020 at 3:33 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Shrinkage.
    Rica25 and ColoradoTJ like this.
  4. Feb 22, 2020 at 3:35 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Whole truck stiffens up. My dash squeaks like a guinea pig in a dryer when it’s super cold.
    Blue Thunder, Rica25 and TTund16 like this.
  5. Feb 22, 2020 at 3:56 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My nitto ridge grapplers get stiff when it's cold but after a few miles they heat up and get smoother. They also vibrate a little also until they get warm.buy it has to be in the 20's or colder
    Rica25 likes this.
  6. Feb 22, 2020 at 5:23 PM
    Northwoods22
    Northwoods22 New Member
    MN
    2013 tundra grade
    Oh yeah everything gets stiff when it’s cold before it gets warmed up, those -20 days the potholes always seem a few feet deeper haha
  7. Feb 23, 2020 at 7:09 PM
    Nice color choice.:thumbsup:
  8. Feb 23, 2020 at 7:42 PM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    My Cooper STT pros are horrible in the cold. My rear end oscillates like crazy. Worse than going up a chain drive hill in a rollercoaster. The rear end of the Tundra is the worst I’ve ever come across....maybe because it’s c channel? I’m not sure but it’s very noodly at times.
    I’d love for an answer because I’ll pay darn near anything to fix it. I’ve considered going back to P rated tires.
  9. Feb 23, 2020 at 7:54 PM
    schymad
    schymad New Member
    David
    2019 Cav. Blue Tundra TRD Sport
    Seeing this thread is reassuring! When it gets 20 degrees or colder, mine vibrates like I've got a flat!! Takes a few miles before it stops. Only truck I've owned that does this.
  10. Feb 23, 2020 at 8:09 PM
    CyberViking
    The Ozarks
    Same. 3 GM trucks and a Titan and none have done this. Unfortunately my commute is a few miles so I just experience it my entire trip.
  11. Feb 23, 2020 at 8:14 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Funny i was thinking the same thing today. My pro suspension was so bouncy today heading to Bozeman. Finally soften a little. This when I wish I had HSC, LSC, HSR, LSR adjustments. Dial in your winter ride.
  12. Feb 25, 2020 at 4:22 AM
    CyberViking
    The Ozarks
    50 degrees today and it was fine. Eventually I’m going to change out the grease on the bushings in the rear and see if it changes anything. If it’s not that then I suspect it’s rubber related, maybe the bushings themselves?
  13. Feb 25, 2020 at 6:29 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Tires are mostly the cause here, not so much the suspension. However everything gets stiffer and harder in the cold.
    15whtrd likes this.
  14. Feb 25, 2020 at 6:38 AM
    Blue Thunder
    Washington
    I’ve noticed the same thing during my morning commutes. The dash starts to creak and snap as the warm air begins to flow through the vents.
    Reminds me of my body when I get up in the morning. Comfortable in bed; comfortable walking around. But that transition requires some stretching, popping and grunting!
  15. Feb 25, 2020 at 6:45 AM
    r1-superstar
    DB
    UTAH
    lol
