Lower strut bolt part number help!!!!!
Discussion in '3rd Gen Tundras (2022+)' started by johnnyconway, Aug 3, 2022.
  1. Aug 3, 2022 at 4:27 PM
    johnnyconway
    johnnyconway [OP] New Member
    2022 Sr5 Tundra
    Trd pro grill-ARE cap
    I managed to destroy the lower strut bolt when trying to put on leveling kit!! Can anyone help me with a part number ? Please! Or a possible solution to my problem. A297ED2B-42F4-4BE5-B2E4-5AD0F31A227D.jpg
  2. Aug 3, 2022 at 4:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You’re 2.5 gen, not 3rd, but here’s your numbers for a 2017
    Shock Absorber Bolt - Toyota (90105-A0382)
    Suspension Control Arm Nut - Toyota (90178-A0084)
  3. Aug 3, 2022 at 4:45 PM
    johnnyconway
    2022 Sr5 Tundra
    I haven’t updated my truck. Sorry. It’s a 2022 sr5 tundra
  4. Aug 3, 2022 at 5:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ahh, makes sense. I sure don’t see much listed online for ‘22 parts, probably easiest to contact your dealer parts dept.
  5. Aug 3, 2022 at 5:47 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
  6. Aug 3, 2022 at 6:09 PM
    johnnyconway
    2022 Sr5 Tundra
    That’s it!! Thanks guys
  7. Aug 4, 2022 at 5:09 AM
    vosaeroplane
    vosaeroplane New Member
    2022 Tundra SR5
    Anybody got part numbers for the two Spindle bolts? I feel like it strips pretty easily so I'd like to have backups.
  8. Aug 4, 2022 at 5:40 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    The 2 bolts that hold lower ball joint? If so, just gotta be careful, if those bolts strip then the spindle threads will probably be damage too. Always thread by hand first. Here are the bolt part# though.
    901015A0449
    vosaeroplane[QUOTED] likes this.
  9. Aug 4, 2022 at 8:10 AM
    johnnyconway
    2022 Sr5 Tundra
    Just to follow up, dealership doesn’t have the bolt I need, southeast Toyota doesn’t have any……trying to order from Toyota directly. I’m trying to re tool the threads/nut but not sure I’ll be successful. If not I’ll have to find something close. I know better than try to work on my truck. Haha
  10. Aug 4, 2022 at 8:52 PM
    vosaeroplane
    2022 Tundra SR5
    Yep definitely! This worries me!
  11. Aug 5, 2022 at 7:51 AM
    roboots21
    roboots21 New Member
    2022 MGM Tundra Limited DC
    These bolts are pretty resilient and DO NOT strip easily. The only time they strip easily is if you hammer them in with an impact wrench before ensuring they are threading in accordingly, but then again that goes for any bolt. They've had this design in the Tacomas and Tundras since at least 2007. Of the 5-6 lifts I've done in both of those models, none of these bolts have been an issue.
    Having done my lift install myself, I'm still wondering and struggling to figure out how the OP messed up that lower strut bolt.
  12. Aug 5, 2022 at 8:08 AM
    johnnyconway
    2022 Sr5 Tundra
    Haha. I’m capable of screwing up pretty much anything. My big mistake was being in a hurry I guess. Used an impact wrench and must have not had threads straight. But, it wasn’t hard to strip it. I didn’t get far and the threads were gone. The rest of the lift went fine after I put the impact wrench away.
    roboots21[QUOTED] likes this.
  13. Aug 5, 2022 at 8:10 AM
    roboots21
    Fair enough! I cringed a little bit watching how much impact wrench Westcott used to install their lift in the YouTube video, and I tented to only use the impact to loosen anything, and even then I mostly only use it on the wheels. Regardless, I hope you can find a bolt in the short term!
  14. Aug 5, 2022 at 8:12 AM
    johnnyconway
    2022 Sr5 Tundra
    Local machine shop was able to make the bolt usable luckily.
