Lower Seat Swap?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraGy, Mar 9, 2019.
  1. Mar 9, 2019 at 4:21 PM
    TundraGy
    TundraGy [OP] New Member
    2014 Tundra
    I have a '14 Tundra SR5. I have wear on the outer edge of the bottom left seat cushion. (I guess my short legs caused my butt to drag across too many times getting in and out.) Is anyone confident if I can swap bottoms with the passenger? I don't care about what you did with your 1972 Pinto seats - I don't have a Pinto. Anyone know on a '14 Tundra? If yes, any precautions with the airbags or other concerns? Any tips?
  2. Mar 9, 2019 at 5:01 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    The driver and passenger side seat bottom cushions and covers are not interchangeable. The cushions have different part numbers and the attachment clips are side specific. Are you wanting to replace them both or just the cover?
  3. Mar 9, 2019 at 5:06 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    I looked into doing this for a bit. The cheapest route is to look on eBay for a take off set. Some people redo the interior with leather etc. and then sell the lightly used ones. The dealer will charge you like $500 per piece brand new. From what I’ve heard it’s not really a diy install
  4. Mar 9, 2019 at 5:07 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I changed them in my 71 Pinto.
    You're welcome..
    Finch and 15whtrd like this.
  5. Mar 9, 2019 at 5:11 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Racing seats :anonymous:
  6. Mar 9, 2019 at 5:11 PM
    Berettafan
    Berettafan New Member
    2017 CM
    not changeable. cutouts for seat belts.
    you can find cushions and covers on eBay.
  7. Mar 9, 2019 at 5:25 PM
    TundraGy
    2014 Tundra
    Thank you all for the replies. I'd be ok with just the cover if that is the most economical route. I will also do an Ebay search. Thanks.
  8. Mar 9, 2019 at 5:27 PM
    KLLVMDCL
    KLLVMDCL New Member
    Brandon
    Austin, Texas
    A good interior guy might be able to cut and replace some of the foam to match the side with less wear too.
    Slayer likes this.
  9. Mar 10, 2019 at 6:52 PM
    Berettafan
    2017 CM
    you could add a piece of thinner foam to that side to build it up a bit.
    couple years ago I got brand new take off cloth interior for a crew max on eBay for $200 or so.
    the seat bottom foam is around $160 iirc.
  10. Mar 11, 2019 at 10:42 AM
    TundraGy
    2014 Tundra
    Thanks for the info. The foam is fine. The cloth is my concern, cosmetic wise and progressively getting worse. I'll search for a cover on Ebay. Thanks!
