Lower mpg, running rough 2010 Tundra 5.7L 35k
Discussion in '2nd Gen Tundras (2007-2013)' started by ReallyConfuzed, Jun 17, 2024.
  1. Jun 17, 2024 at 12:48 PM
    ReallyConfuzed
    ReallyConfuzed [OP] New Member
    2010 Tundra 5.7L
    None
    2010 Tundra 5.7L with 35k original miles.
    Parents truck that doesn't get driven much. Running rough, shaking a lot. About 12mpg. Seems to get worse as the gas gets lower in the tank. I looked for the inline fuel filter. Guessing it's in the pump. Some times fuel injector cleaner helps, but get to end of tank and starts running rough again. Any thoughts? I don't want to redo the injectors if it is something with the gas/pump/filter that needs addressed first.
    I'm open to all thoughts.
    Also, What is the easiest way to drain the tank? Is there an easy port to access on the tank to get a pump into the bottom?
  2. Jun 17, 2024 at 2:47 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Check out the reviews on Royal Purple Max Clean. It’s worked great for me. You will need more than one can, since 1 can does 20 gallons. The best way to use it is to add it to the tank, then fill, then take a long drive at one time using at least 1/2 tank. May have to do it twice. Good luck
  3. Jun 17, 2024 at 3:05 PM
    ReallyConfuzed
    2010 Tundra 5.7L
    None
    What is the tank size on a 2010 5.7l?
  4. Jun 17, 2024 at 3:58 PM
    Danny3737
    I think it’s 26.4
  5. Jun 17, 2024 at 4:00 PM
    Danny3737
    Even though you have low mileage, it probably wouldn’t hurt to change the plugs & PCV after 14 years.
    Cruiserpilot and MTRock like this.
  6. Jun 17, 2024 at 4:06 PM
    2mchfun
    Clean the throttle body, replace the air filter, pour 2 cans of Berryman's B12 in a half tank of gas and get it out on the highway from 60-80mph for a couple of hours.
    Cruiserpilot likes this.
  7. Jun 17, 2024 at 4:41 PM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    Try cleaning the MAF.
  8. Jun 17, 2024 at 5:38 PM
    Danny3737
    You are barely driving 3K miles a year. Are you sure you don’t have some skunky gas in there. If you are barely driving it , it wouldn’t hurt to keep the tank full with some fuel stabilizer in it.
  9. Jun 18, 2024 at 3:55 AM
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    Is it a Flex Fuel 5.7?
    Mr Badwrench likes this.
  10. Jun 18, 2024 at 12:56 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I just got a 2010 5.7 with 325000 KM on it. It gets 22 mpg. But thanks to you all for the direct instructions
    to give it an initial tune.
  11. Jun 18, 2024 at 1:02 PM
    ReallyConfuzed
    2010 Tundra 5.7L
    None
    How are you getting 22mpg? Was something changed or upgraded? It's only rated for 16mph highway?
  12. Jun 18, 2024 at 1:08 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    No, I'm old and drive consistently. It goes downhill fast when I go fast. But that's what I get just puttering around
    and on the open road with no load.
  13. Jun 18, 2024 at 1:09 PM
    grayscale
    DFW
    He's got an RCSB so it's a good bit lighter than most
  14. Jun 18, 2024 at 1:10 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    its not in km/gal?
  15. Jun 18, 2024 at 1:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    When you say running rough what do you mean? Does it smooth out as the rpms go up? Does it rev up normally?
  16. Jun 18, 2024 at 1:25 PM
    Danny3737
    The best I have ever got was 17.5, but as soon as I go over 70 it will drop to a little above 15. My work truck is a 2023 Sierra with the 2.7 Turbo 4 cyl. That gets around 25 if you keep it under 70. Over 70 it’s around 20 MPG. I will say that I’m shocked with the power it has, but I wouldn’t expect it to last over 150K before it will need some major work. You can hear the turbo whine every time you give it even a little gas
  17. Jun 18, 2024 at 1:59 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Nope.
  18. Jun 18, 2024 at 2:01 PM
    grayscale
    DFW
    That would be like 13.5 Mpg which would be terrible
  19. Jun 18, 2024 at 2:42 PM
    Retired...finally
    Have you checked the air filter?
  20. Jun 18, 2024 at 2:57 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Any codes?
