Lower knuckle swap with lift for camber
Discussion in '3rd Gen Tundras (2022+)' started by alex17117, Sep 3, 2024.
  1. Sep 3, 2024 at 7:14 AM
    alex17117
    alex17117 [OP] New Member
    Alex
    2024 limited, Lunar Rock
    I have the Eibach 2.6 lift in the front and have struggled to get a good camber value with alignments which has led to increased outer tire wear. Curious if anyone has installed the lower knuckle from the trd lift kit without the other parts and had good results? Also, are there other solutions out there to help correct camber geometry?
  2. Sep 3, 2024 at 7:15 AM
    alex17117
    Alex
    For reference, these are the trd lift knuckle parts: pt981-34310 and pt981-34320
  3. Oct 8, 2024 at 11:58 AM
    bobleaux
    bobleaux New Member
    Did you ever give this a try?
  4. Oct 8, 2024 at 4:41 PM
    gesekee19
    gesekee19 New Member
    After market upper control arms?
    ShinyConcretE likes this.
  5. Oct 8, 2024 at 5:15 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Sounds like you need to find a better place to do your alignment.
  6. Dec 11, 2024 at 7:36 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    ever end up doing this?
