Lower inner front fender plastic; keep or no?
Discussion in 'Wheels & Tires' started by Cement, May 9, 2019.
  1. May 9, 2019 at 9:24 AM
    Cement
    Cement [OP] ...
    2019 Cement Trundra TRD
    With my new wheels I'm rubbing the lower inner front fender plastics at full lock
    After some trimming
    After reinstall and testing I still need to trim some more.
    My question is as I'm removing material, the panels are getting flimsier. Seems to me they'll flap around pretty good on the road. So I'm wondering after all the required trimming, and with the possibility of them flapping around, whats the benefit to keeping them? What has everyone else done/decided? Pluses and minuses?
    Thanks in advance
  2. May 9, 2019 at 5:30 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Well this is what I did. Hacked my stock units to shit so they would fit. Wasnt happy with how they looked or the rigidity so I bought new OEM units took my time relocated a bit and now they look factory. I'd keep them if you can. Keeps the fogs dry.
    15whtrd and Black Wolf like this.
  3. May 9, 2019 at 6:32 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I would try to keep as much as possible, it helps keep some junk out.
    Novajess1972 and Watt maker like this.
  4. May 10, 2019 at 9:36 AM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    Agreed ^^^
  5. May 10, 2019 at 10:54 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Mine got trimmed and then I pushed it back so it’s behind those 2 bolts that are sticking up and haven’t had a problem. Like other say keep as much as u can so u don’t have random things going in there
    Tundyfundy and NewImprovedRon like this.
  6. May 10, 2019 at 10:58 AM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Happen to know the part numbers for the OEM replacements for a 3rd gen? Mine got destroyed as well
  7. May 10, 2019 at 11:38 AM
    Novajess1972
    Jesse
  8. May 10, 2019 at 11:48 AM
    smy
    smy New Member
    the shop that installed my suspension fabricated a piece/cover for that exact location. They're installing the cover today. I'll post a pic when done
  9. May 10, 2019 at 11:50 AM
    Novajess1972
    Jesse
    Part numbers for both sides TO1248192, TO1249192
  10. May 10, 2019 at 11:52 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    You can use kydex that is thicker to mold another yourself.
    I did that for my search and rescue truck.
    Just get a heat gun and warm it slowly. once it is warm enough to flex place it over the other one and wait for it to cool.
    Drill the holes and you have a custom cover for a couple bucks
    ZPMAN, ManoTundra and Tundyfundy like this.
  11. May 10, 2019 at 11:52 AM
    YotaMan
    Colorado Springs
    2021 Platinum
    Thank you
  12. May 10, 2019 at 11:55 AM
    Novajess1972
    Jesse
  13. May 10, 2019 at 3:51 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Just for reference what mine looks like
    Cement[OP], plumber802 and equin like this.
  14. May 11, 2019 at 8:08 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    I’m interested to see this. Do post pics when done.
  15. May 11, 2019 at 8:18 AM
    Cement
    Cement [OP] ...
    Thanks for the feedback guys. Keeping them is the right call. And therefore, job done:
    Best tool I ended up using was a box cutter/razor blade. It cut the plastic like a hot knife thru butter so I was able to make cuts around the contours/bends of the panel allowing me to retain most of its rigidity. Still dont like how floppy it seems where its held on by the plastic rivet, but thats a function of the rivet and not the panel. Was like that before so I assume it'll be ok now.
    Thanks again.
    equin and Xyleff like this.
  16. May 12, 2019 at 8:06 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I took mine off last summer intending to cut and reinstall but haven’t gotten around to that yet. I agree that the cover appears to be designed to protect the fog lights from dirt and mud and such. I’ve taken it off-road and driven through some mud since last summer and luckily the fogs have held up. Granted, not the ideal way to protect and maintain the fogs, but laziness and procrastination have gotten the better of me.
  17. May 13, 2019 at 12:59 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I was able to heat and trim mine so that I got no rubbing but your method looks like a real good one as well. Thanks for posting the pics.
  18. May 13, 2019 at 6:22 PM
    smy
    smy New Member
    Not OEM look but works. Re-routed the wiring to the side.
    TRD.LTD likes this.
  19. May 14, 2019 at 12:28 PM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    This is exactly what I was going for. Was trying to have a guy fab one up for me but he doesn’t have access to a tundra and he’s not local. How much did they charge?
  20. May 15, 2019 at 10:12 AM
    smy
    smy New Member
    Wasn't charged for the actual part. I'm assuming since it was the same shop I bought the tires, mount/alignment, had suspension installed, and had the CMC done that the cost for all of that work covered these fog light covers.
    Let me know if you want a photo of just the cover. It's pretty easy to remove.
  21. May 15, 2019 at 11:36 AM
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    @smy yea, I’d love to see if you have a photo of it. If you could, ask that shop if they’re willing to make another set and for how much. If not, no worries.
  22. Jul 31, 2020 at 9:52 PM
    Christophlim
    Christophlim New Member
    Denver, CO
    2017 SR5 DC
    is this for all third gens? got a used 2017 and it never came with these.
  23. Aug 10, 2020 at 12:50 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
    Christophlim - Yes, the part numbers will fit your truck.
    I heated my originals and did not like the outcome, so I ordered new ones off ebay. I did not trim the new ones, took the bolts and screws out of the bottom of the bumper and shoved the bottom of the plastic forward several inches. No more rub, and I still have my splash guards.
  24. Sep 22, 2024 at 5:19 AM
    TRD.LTD
    TRD.LTD New Member
    john
    Grey Tundra Limited
    wheels lift
    Any updates with the photo? its been 5 yrs? lol
