lower gear rear end?
Discussion in '2nd Gen Tundras (2007-2013)' started by btolleson, Nov 25, 2014.
  1. Nov 25, 2014 at 6:05 AM
    btolleson
    btolleson [OP] New Member
    bobby
    tundra 2007
    none
    I have a 07 tundra sr5 4.7 2 wheel drive, can i get a lower gear rear end for the truck to help with gas mileage?
  2. Nov 25, 2014 at 7:11 AM
    I'm sure you can...but if you bought a v8, why worry to much about fuel? I almost bought the 4.7...but the 5.7 had so much power, and not much of a noticeable difference in fuel.
  3. Nov 25, 2014 at 9:58 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Did you upsize the tires? If not your set to the optimum gears already. You would loose top end and get more low end with gears. Would help mpg at lower speeds but hurt at higher speeds. Also the return on investment would most likely be longer than you would have the truck. For example I figured it out for the price of a used motorcycle I bought vs the mpg savings from the Tacoma I had at the time, the roi was around 30 years, just to break even.
  4. Nov 25, 2014 at 11:23 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Better off spending a couple grand on a little corolla or something.
