Lower driver and passenger seats options?
Discussion in '2nd Gen Tundras (2007-2013)' started by Truckerware, Jun 6, 2024.
  1. Jun 6, 2024 at 7:16 PM
    Truckerware
    Truckerware [OP] Trucker Ware
    Keith
    Kansas
    2007 silver quad cab
    I am 6’ 4” and the seats set way to high for my preference and comfort! Especially since I am a truck driver (18 wheelers). So I’m used to setting on floor! Have thought about seeing if Tacoma seats will bolt up and set at a more comfortable level! Even thinking about cutting the braces in have!
  2. Jun 28, 2024 at 7:40 PM
    Pir8hippo
    Pir8hippo New Member
    Brandon
    2011 Toyota Tundra Platinum Crewmax
    USB ports, Diode Dynamics SS3 Wide Fog
    I purchased a set of seat jackers from Desertdoesit for the front, which lifted the front about an inch of I remember correctly, rear stayed the same. Gave more lean to the seat, which eased the pain that I felt in my thighs and lower back… I’m 6’1 and adding height to just the front… I believe they might help you as well from feeling so close to the roof…
  3. Jun 28, 2024 at 8:02 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I did the same with a piece of 1” sq tube with a hole drilled thru for the bolt. It was free and stopped that infernal forward sliding. Raised the knees, really helped.
