Lower dash below the radio
Discussion in '2.5 Gen Tundras (2014-2021)' started by 16 blue crewmax, Dec 22, 2019.
  1. Dec 22, 2019 at 5:59 AM
    16 blue crewmax
    16 blue crewmax [OP] New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    I'm looking for the lower dash plastic under the radio that's in the 2020 model it has cell phone charger port and openings for factory style switches
  2. Dec 22, 2019 at 7:57 AM
    16 blue crewmax
    Doug
    Richmond Virginia
    How do I get in touch with him
    NewImprovedRon likes this.
  3. Dec 22, 2019 at 2:32 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Thank you no hurry
  4. Jan 8, 2020 at 6:43 AM
    16 blue crewmax
    Doug
    Richmond Virginia
    Any updates on this
  5. Jan 8, 2020 at 6:53 AM
    He was on vacation. I'm sure he will reply soon.
    @Roman
  6. Jan 8, 2020 at 7:16 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  7. Jan 8, 2020 at 9:45 AM
    16 blue crewmax
    Doug
    Richmond Virginia
  8. Jan 8, 2020 at 9:57 AM
    coTony
    Tony
    Montrose, CO
    I would like to see a picture of this item
  9. Jan 9, 2020 at 1:01 PM
    Roman
    Roman
    Franklin, TN
    Just click on that link and order away. :)
  10. Jan 9, 2020 at 1:07 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Thank you
    Roman[QUOTED] likes this.
  11. Jan 10, 2020 at 5:24 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Here is the picture
    Wallygator likes this.
  12. Jan 11, 2020 at 5:19 AM
    coTony
    Tony
    Montrose, CO
    Not sure what I would do with all the extra switch openings
  13. Jan 11, 2020 at 5:26 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    More USB charging ports, exterior/interior/bed lighting switches, winch switch, ejecto-seato cuz, inverter power outlets, extra gun mag holder, dental floss dispenser, urinal tube, drinking tube, PEZ dispenser...
  14. Jan 11, 2020 at 6:57 AM
    coTony
    Tony
    Montrose, CO
    I prefer Switch Pros so I do not have a TON of wire coming through the dash. I have a couple hidden switches I put on mine down there. This does open up opportunities for others that need the extra openings. Not a bad price either
  15. May 11, 2020 at 6:30 PM
    trd.james
    trd.james New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    Any chance you have a picture of the back? I can’t get mine off and am trying to see where the clips are
  16. May 11, 2020 at 6:53 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Use i plastic pry tool and pry from the top iys tough but will come out
    trd.james[QUOTED] likes this.
  17. May 11, 2020 at 7:02 PM
    trd.james
    James
    I’m using a plastic pry tool. I’ll try again, thanks!
  18. May 11, 2020 at 7:29 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    It's definitely tough but it does come off
  19. May 11, 2020 at 8:09 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    So what kind of switch goes will fit that big spot, 2nd spot? What is in there in the 2020 Tundra?
    1lowlife likes this.
  20. May 11, 2020 at 9:20 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I want to know this as well..
  21. May 13, 2020 at 8:26 AM
    Roman
    Roman
    Franklin, TN
    Looks like the USB charger socket goes there.
  22. May 13, 2020 at 12:38 PM
    trd.james
    James
    I got done btw. Wasn't actually that hard, I was just being too careful.
  23. May 13, 2020 at 3:14 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    Here is the one I have for the lower section
  24. Jul 19, 2020 at 5:01 PM
    radiantR15
    radiantR15 New Member
    2015 RR limited
    Anybody have the part #'s for the usb outlets/switches that fit the 2020 tundra switch bezel? i wanna add more switches and get rid of one of the 12v outlets in my 2015.
    also can i use the wire that powers the 12v outlet to supply the power to the usb swithes?
  25. Jul 19, 2020 at 5:14 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    That's clean. I like that. Which switches are you using? They look OEM.
    radiantR15 likes this.
  26. Jul 19, 2020 at 5:24 PM
    radiantR15
    2015 RR limited
    the oem usb switches/part#'s ..pictured
  27. Jul 20, 2020 at 3:16 PM
    16 blue crewmax
    Doug
    Richmond Virginia
    They are from air on board the ones that fit our trucks start with 8
  28. May 13, 2021 at 11:58 AM
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
    Who has put one of these in an older model? Mine is a 2016 and I'd like that double 2.1 amp USB plug, as well as the other extra switch panels.
  29. May 13, 2021 at 7:46 PM
    radiantR15
    2015 RR limited
    Here’s what I ended up with.
