Lower control arms questions
Discussion in 'Sequoia 2nd Gen (2008-2022)' started by Fttx, Jun 29, 2025 at 2:35 PM.
  1. Jun 29, 2025 at 2:35 PM
    Fttx
    Fttx [OP] New Member
    Yesterday
    Hi,
    First post here.
    I bought at 2013 Sequoia with 175K miles. I had an oil change and brake job done for a great price at Toyota of North Austin. I got a full maintenance check done there too. They let me know that both lower control arm bushings are leaking and quoted me $2446 to replace the arms.
    Would something like this be good?
    https://freedomoffroadusa.com/oem-r...l-arms-w-cam-bolts-and-ball-joints-fo-t703fl/
    If not, is there a recommended kit that is as good as OEM but cheaper?
    Is OEM better?
    Should I avoid used parts off of eBay for this type of wear item?
    Is there anything else I should replace while getting this job done?
    Thanks for any help!
  2. Jun 30, 2025 at 4:33 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    OEM only, for lowers. Freedom off road has some good prices, I got my uppers from them.
