Lower control arm options
Discussion in '1st Gen Tundras (2000-2006)' started by Voss, Aug 23, 2021.
  1. Aug 23, 2021 at 6:33 PM
    Voss
    Voss [OP] Dust in the wind
    Valod
    2003 AC TRD 4x4
    Hi all, so today I took my truck to a local shop to find out what was causing the squeaking in my suspension. Turns out its the lower control arm bushings. The shop told me toyota doesn’t sell the bushings and to get OEM LCAs is fairly expensive.
    Wondering what my possible options are here? Any aftermarket bushings that are reliable? If not, any aftermarket LCAs I may want to consider since OEMs are fairly expensive?..
    Thanks!
  2. Aug 23, 2021 at 6:38 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Toyota does sell bushings but they're very expensive. I went with Beck Arnley lower arms (bushings included) and so far they're alright. They sent two different arms from two different manufacturers so the matter of quality is hard to gauge.
    Voss[OP] likes this.
  3. Aug 23, 2021 at 6:47 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Do you remember how much the OEM bushings were? How long have you had your LCAs?
  4. Aug 23, 2021 at 7:15 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The bushings are around 70 each, all 4 is around 300. Getting the old ones out looks like a pain. There is a method where you use the stock bottle jack and put it between bushings to press them outward. I tried that and bent my lower arm, maybe I should have torched it first.
    I looked into aftermarket ones but didn't want to risk the poly squeaking. I believe White Lighting or something like that makes poly bushings for our trucks on the cheap. To install them you have to reuse sleeves from the stock bushings.
    I have had beck arnley since January 2019. Here you can see where the bushings have wide shoulders on the outside ends. Thats why removal looks painful if you want to reuse any of the stock bush. I can only see cutting the shoulder off and pressing them out as an option. Maybe the jack move works with a torch.20181210_170717.jpg
    Voss[QUOTED][OP] likes this.
  5. Aug 23, 2021 at 7:28 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thanks bud
  6. Aug 23, 2021 at 7:40 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    what noise is the suspension making? is it like a spring mattress on prom day every time it moves?
    infernotundy, TRDGen and Voss[OP] like this.
  7. Aug 23, 2021 at 7:47 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Thats exactly the sound it makes.
    FrenchToasty likes this.
  8. Aug 23, 2021 at 7:47 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats what mine sounded like
  9. Aug 23, 2021 at 9:22 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Hahahaha same noise here.
  10. Aug 23, 2021 at 11:44 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Wonder how many good sets of these have been thrown out since the frame recall? Mine seemed alright before but they replaced the LCA's with frame recall and I sure as hell wasnt gonna stop them.
    jerryallday likes this.
  11. Mar 10, 2025 at 12:46 PM
    fishordie
    fishordie New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    you were getting it on prom day before the prom??
