Lower control arm bolts stuck
Discussion in 'Suspension' started by BlueFalconActual, Oct 7, 2016.
  1. Oct 7, 2016 at 7:12 AM
    BlueFalconActual
    BlueFalconActual [OP] Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Hey all,
    Im balls deep into getting my 6112 coil overs put in but I cannot for the life of me loosen the lower control arm bolts. My impact gun wont budge them and Ive already broken a breaker bar trying to get it loose. Any tips? Is there any trick to getting the coilovers installed without having to drop the LCA?
  2. Oct 7, 2016 at 7:18 AM
    Take a pic of where you have the sockets. Your probably doing the same thing I did for a second.
    Tundyfundy likes this.
  3. Oct 7, 2016 at 7:18 AM
    Large
    Large New Member
    ^^^^^^^^ prob putting the socket on the cam tab and not the nut / bolt.
    Tundyfundy, 2cID and ColoradoTJ like this.
  4. Oct 7, 2016 at 7:21 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  5. Oct 7, 2016 at 7:21 AM
    Yep. The sockets go on the inside of the lower control arm.
  6. Oct 7, 2016 at 7:22 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Sorry if those aren't clear enough.
  7. Oct 7, 2016 at 7:22 AM
    Vizsla
    Vizsla pretend2send
    You have to loosen and tighten both front and rear from the front. If you are cranking on them from the rear they won't move. So back loosen nut, front loosen bolt, easier without skid plate on.
    Les7311 likes this.
  8. Oct 7, 2016 at 7:22 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Somamabitch. The manual lied to me
  9. Oct 7, 2016 at 7:22 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Thanks guys!
  10. Oct 7, 2016 at 7:23 AM
    Swap the sockets to the inside and a back up wrench on the outside. They should break free.
  11. Oct 7, 2016 at 7:24 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Update?
  12. Oct 7, 2016 at 8:13 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Im about to take my daughter to school and pick up a new breaker bar. just to clarify, I need to loosen the nuts on the inside of the LCA correct?
  13. Oct 7, 2016 at 8:20 AM
    Yep.
    You got this boss.
    BlueFalconActual[OP] likes this.
  14. Oct 7, 2016 at 8:25 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep, had the same exact problem. Just have to loosen the insides
  15. Oct 7, 2016 at 8:27 AM
    Vizsla
    Vizsla pretend2send
    You have to loosen the front bolts by the bolt(front) not nut.
  16. Oct 7, 2016 at 9:22 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Eureka!!! Thanks guys!
    TheBeast likes this.
  17. Oct 7, 2016 at 1:31 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I love a happy ending story.
  18. Oct 7, 2016 at 2:13 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    You had me at happy ending
    2cID, aperezsh, MotoTundra and 2 others like this.
  19. Oct 7, 2016 at 2:23 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I didn't remove those bolts to add new coilovers. Just remove the two bottom bolts of the spindle and it will remove it from the lower control arm.
    Push down on the lca with your weight to make room for the new coilover.
    2cID and BlueFalconActual[OP] like this.
  20. Oct 7, 2016 at 2:24 PM
    csuviper
    Broomfield, CO
  21. Oct 7, 2016 at 2:28 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I tried that but couldn't get it to fit. I must have had Carnation Instant-Bitch for breakfast this morning.
    Tundyfundy, Law323, 2cID and 5 others like this.
  22. Oct 7, 2016 at 2:31 PM
    csuviper
    Broomfield, CO
    lol
  23. Oct 7, 2016 at 9:38 PM
    Vizsla
    Vizsla pretend2send
    Excellent
    No, LOL, virtually impossible on your own with a 2.5" coil over. Upper and lower stock control arm bushings are rubber torsion bushings, and need torqued at ride height anyways. There is almost no chance all four lowers get adjusted during alignment(usually backs get maxed, fronts untouched).
    Relentless likes this.
  24. Oct 7, 2016 at 10:22 PM
    No pictures of the truck yet? Are you still under the truck Kevin?
    NewImprovedRon likes this.
  25. Oct 8, 2016 at 6:36 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Thanks again for all the help you guys. It was a total piece of cake after I got the LCAs to drop.
  26. Oct 8, 2016 at 6:50 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    ColoradoTJ likes this.
  27. Oct 8, 2016 at 7:01 AM
    Looks great!!!
    Glad everything went smooth for the rest of the job.
    MotoTundra likes this.
  28. Oct 8, 2016 at 8:18 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Will do. Got my alignment done yesterday afternoon, but looking at the truck head on, it looks like I have some positive camber which makes me wonder if they even did anything. Serves me right going to a place right outside of base. I'm gonna see if I can get someone else to look at it before I head off road.
  29. Oct 8, 2016 at 8:35 AM
    Post your alignment sheet. If you can see it with your eyes, that would have me concerned too
  30. Oct 8, 2016 at 8:35 AM
    csuviper
    Broomfield, CO
    I must be a :muscleflexing: then ;)
