Lower Ball Joints
Discussion in '1st Gen Tundras (2000-2006)' started by Strob3, Jun 11, 2025 at 6:47 PM.
  1. Jun 11, 2025 at 6:47 PM
    Strob3
    Strob3 [OP] New Member
    Hello, I just wanted to ask if there are any warning or signs of lower ball joint failure, or do they just go? If they don't show symptoms of anything should I replace them anyway? Or should I wait until they start having symptoms of failure? And what do they usually do before they fail?
  2. Jun 11, 2025 at 7:45 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    You might hear a clunking sound when you 1st start reversing from the front end. You can check if they have any play by jacking the truck up and prying around it with a crowbar.
    Overall we try to change them out every 100k miles no matter what and always OEM.
  3. Jun 11, 2025 at 7:51 PM
    There’s a thread on here with 20+ pages of LBJ failure pics.
    Probably half the people in those posts had zero symptoms ahead of time.
    100k is conservative lifespan, LBJ are a wear item, and never use anything except OEM LBJ. The majority of pics on that 20+ page thread are aftermarket LBJs failing, some with as few as 5,000 miles on them.
  4. Jun 12, 2025 at 1:52 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Like both gentlemen have already stated, OEM LBJs are a wear item that should be replaced by mileage or time.....10yrs or 100k miles. I bought a 2005 FGT one year ago and my LBJ failed in January @ 145k miles and 17yrs. I only had a subtle wandering sensation in the lead up to the failure. No noise or vibration. Looking back at photos when I purchased it, there was indication of leaking grease but I didn't immediately recognize this. Since you are obviously thinking about this, just change them. I wish I would have.
  5. Jun 12, 2025 at 2:02 PM
    The Black Mamba
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Change them at the same time you do the timing belt so that they are on the same schedule.
    G_unit3000 likes this.
  6. Jun 12, 2025 at 3:37 PM
    Mark4x2
    Mark4x2 New Member
    Ohio
    2003 AC stepside 4x2,2021 SR5 Crewmax 4x2
    OEM LBJ for shure and new OEM bolts also:thumbsup:
