lower ball joint to steering knuckle threads stripped
Discussion in '1st Gen Tundras (2000-2006)' started by PowSlayer, Aug 18, 2020.
  1. Aug 18, 2020 at 4:38 PM
    PowSlayer
    PowSlayer [OP] New Member
    2000 Tundra
    While trying to torque the steering knuckle bolts down to 59ft/lbs the 2 bolt holes closest to the backing plate must have stripped. They spin freely tightening ever so slightly to become loose again. Does this mean I am left getting a new steering knuckle? Or is there a safe alternative to putting new threads in.
    Thanks in advance guys
  2. Aug 18, 2020 at 6:28 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    You could oversize the hole by one size and re-tap it for a larger bolt. If I recall, those are 14 mm bolts that hold the LBJ in place. You could tap them to Either a 1/2-28 or 9/16-28 bolt or what ever one size larger would be.
  3. Aug 18, 2020 at 6:42 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Could helicoil it or upsize the bolts (you'll have to drill out the LBJ through holes, and the shear/alignment cones will no longer work though). Helicoil would keep everything "stock", though I would get good ones and be careful for the whole process since they're easy to fuck up.
  4. Aug 19, 2020 at 4:53 AM
    Professional Hand Model
    Hand Protectors
    This stinks as you obviously were following the torque spec. Which brand LBJ are we using?
    I ask this as a learning question as I’ve never done this LBJ replace and would like to prevent a similar scenario.
    Pucks18 likes this.
  5. Aug 19, 2020 at 5:20 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wonder if these are the same 2 I snapped. I can't tell from your description. I managed to break two of these.My torque wrench never clicked when tightening. I was able to get both out with vice grips.
    Casper421 and N84434 like this.
  6. Aug 19, 2020 at 7:23 AM
    jbar322
    jbar322 New Member
    Harmony, PA
    2002 Silver Tundra AC SR5 TRD
    Fuel Offroad Beast Rims-Black Machined with Dark Tint (17x9,-12 offset, 4.5 backspacing), Dick Cepek 285/70R17, Eibach Adjustable Front shocks with Eibach Springs w/Supreme Suspension Leveling spacer, SPC UCA, Toytec Progressive Add-a-leaf, Toytec Boss Rear Shocks, SuspensionMaxx Sway bar end links, Toytec Front Diff Drop, Toyota LBJ, Mevotch LCA, Proforged Tie Rod Ends, Carquest CV Axles, K&N Air filter, Rear Diff vent relocate, A/C Delco Rack and Pinion Assembly, Carquest Platinum Brakes/Rotors
    If it was me, I would drill the hole, tap it, and upsize the bolt, such as other people have posted. I can't confirm if it will cause a problem with the shear/alignment cones or not, as other people posted. You will definitely be taken away some metal, but I don't believe that a small amount would matter. Based on your original post, you would only be drilling the 2 holes, next to the backing plate. So, it should not change the shear/alignment cones strength in my opinion...but what do I know.
    I did the same as FirstGenVol, I snapped off a bolt, before the torque wrench clicked, and was able to get the bolt out with vice grips. My bolt did snap off in the hole near the backing plate. At that point, I was reusing the stock bolts. After that, I purchased all new OEM bolts and I did not have any issues with the correct torque. It did take 2-3 weeks to get new stock OEM bolts from the dealership. I guess they are hard to find.
    Good Luck.
    N84434 likes this.
  7. Aug 19, 2020 at 8:11 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Oddly enough, when I rebuilt the front end on my Tundra, I had no issue getting the old bolts out. Something I was almost sure would break and cause me grief, came out like they'd been out a month before... Go figure..
    Casper421 likes this.
  8. Aug 19, 2020 at 9:25 AM
    PowSlayer
    2000 Tundra
    I think helicoil would be the only option correct? unless I drill the holes in the lower ball joint aswell? Wouldn't helicoil be an easier process in this case?
  9. Aug 19, 2020 at 9:27 AM
    PowSlayer
    2000 Tundra
    The bolts did not snap off for me.. they just went real loose and are now "floating" around in the steering knuckle.
  10. Aug 19, 2020 at 10:18 AM
    PowSlayer
    2000 Tundra
    I have taken out the other 2 bolts now and the 2 against the backing plate will not come out.... they are still holding the LBJ to the steering knuckle, but with some play. This is not safe to drive on Eh? Any advice on getting the floating bolts out if not?
  11. Aug 19, 2020 at 10:50 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Use a prybar or screw driver and get some leverage to pry between the knuckle And the LBJ, putting pressure against the bolts. Back them out while applying the leverage.
  12. Aug 19, 2020 at 12:03 PM
    PowSlayer
    2000 Tundra
    thanks this worked like a charm
    Does anyone know the thread size of the LBJ to steering knuckle bolts?! Trying to find out what size helicoil I will need for it. Thanks again guys!
  13. Aug 21, 2020 at 4:20 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Just asking because I don't see it mentioned above: are you sure it's the threads in the steering knuckle that are stripped and not the threads on the bolts? The steering knuckle is a cast iron piece, I would expect the theads on the bolt to give out before the threads in the knuckle. It would also be much easier to correct if the problem was with the bolts: just chase the threads in the knuckle and buy new bolts. Worth checking.
    FirstGenVol and bmf4069 like this.
