Lower Ball Joint Caution
Discussion in '1st Gen Tundras (2000-2006)' started by 2uzfe2000, Jun 22, 2022.
  1. Jun 22, 2022 at 11:33 PM
    2uzfe2000
    2uzfe2000 [OP] New Member
    I recently replaced my lower ball joints and found something interesting/scary. The Toyota bolts are extremely soft and I wonder if they are causing people to have failures. The service manual states to torque the 8 bolts (4 on each side) to 59 ftlbs. Good luck with that, I ended up snapping the head off of one completely, and I took the rest out and all were severely stretched.
    The bolts are part numbers 9011910933 (these go over dust protector holes) and 9010510505. Having stretched bolts in a critical suspension component is a major safety hazard and a disaster waiting to happen. I couldnt torque them down past 40 ftlb's without them stretching, so that is what I did with a new set of bolts.
    To anyone doing their lower ball joints, watch for stretched bolts.
    Neo likes this.
  2. Jun 22, 2022 at 11:36 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Are you sure about the 80 lbs? I think they are more like 56.
  3. Jun 22, 2022 at 11:39 PM
    2uzfe2000
    Sorry youre right. I torqued to 59 ftlbs not 80 I re-read the manual again when I posted and saw 80nm. The bolt head snapped at 56 ftlbs. I made the correction in the original post.
  4. Jun 22, 2022 at 11:43 PM
    alb1k
    Left Coast
    It's good
    I'm not right often, I looked it up on an 05-06
    Connect the lower ball joint with lower ball joint dust cover protector to the steering knuckle with the 4 bolts.
    Torque: 65 N·m (662 kgf·cm, 48 ft·lbf)
    We may be talking different years. I only remembered because I did them this year and thought it was low. But I've also learned I tend to over torque if I don't look it up.
  5. Jun 22, 2022 at 11:43 PM
    2uzfe2000
    tvpierce and alb1k like this.
  6. Jun 23, 2022 at 4:18 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I broke two of mine also. Good times.
  7. Jun 23, 2022 at 8:38 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
  8. Jun 23, 2022 at 9:47 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Loctite and hand tight with a 16 inch socket wrench is what I do. Although loctite isn’t needed with the natural corrosion my vehicle gets.
    BroHon, artsr2002 and Filthyphil like this.
  9. Jun 23, 2022 at 10:13 AM
    Little niggling detail to point out here, if your copy/pasta from the owner's manual is correct.
    OP is saying he torqued to 56 ft·lb. The manual states they're to be torqued to 65 N·m.
    So yes, it makes sense they would snap or stretch well into the 50s of foot-pounds. 56 foot pounds is nearly 76 Newton meters! Already tighter than OEM spec. [Edit...] 48 foot pounds would put you on target @2uzfe2000
    If so, this is a classic mistake to make. And there are some places - as I think @FirstGenVol found out with his transmission pan bolt(s)? - that Toyota flip-flopped the two, which doesn't help.
  10. Jun 23, 2022 at 7:11 PM
    2uzfe2000
    The 2000-2003 service manual asks for 80nm.
  11. Jun 23, 2022 at 7:37 PM
    Is it potentially a part change issue? Or a misprint in the manual?
  12. Jun 24, 2022 at 4:31 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Everyone thinks I broke my trans pan bolts. :notsure:I did not. I just stripped the drain plug. Manglers don't lie. :hattip:
    G_unit3000 and Jack McCarthy like this.
  13. Jun 24, 2022 at 7:23 AM
    Hence the (s) at the end of bolt(s). Drain plug would be "bolt". Pan bolts would be "bolts". "bolt(s)" covers both bases.
    But am I wrong, was the torque value in the manual incorrect?
  14. Jun 24, 2022 at 7:46 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't remember.
  15. Jun 27, 2022 at 2:19 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  16. Jun 27, 2022 at 2:38 AM
    w666
    Maryland
    Someone at Loctite apparently earned their PhD with the "thesis" attached. Fascinating reading (if you have all day), and way more information than any one human needs.
    https://dm.henkel-dam.com/is/content/henkel/LOCTITE-Threadlocker-Manual
    The Internet suggests that torque should be REDUCED by ~ 20% when using thread locker to prevent the elongation of bolts due to over tightening. Section 6 in the Loctite Manual (pg 30) addresses this.
    That said, however, OEM bolts appear to be factory coated with Loctite (or some such thing), so I'm confident that their torque recommendations reflect this. If you ADD Loctite (or anti-freeze, et al)...beware.
    JasonC. and tvpierce like this.
  17. Jun 27, 2022 at 5:42 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Bmktw2 likes this.
  18. Jun 27, 2022 at 6:07 AM
  19. Jun 8, 2023 at 9:16 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Bringing this up again because I just did the same thing to one of the bolts, glad I kept the other 8 that I replaced (the threads are still good, I was being proactive).
    Wanted to check the torque and "pop", a start to bad evening. Let it be known that I was being a dumba$$ and left it on the ground, so the downward force didn't help. Also, kids, don't do truck stuff when you're sick...no matter how OCD you are feeling. You will no think good.
    Luckily (maybe, hopefully, praying) a decent amount of the threads came off with the head, so I might be able to work it straight through without much trouble.
    shifty` and bmf4069 like this.
  20. Jun 8, 2023 at 11:46 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I hope you are able to remove the broken bolt with little fuss. But why are you rechecking the torque? These aren't lug nuts. If anything I'd liken them to "torque to yield" head bolts. Plus you install them with a gob of red loctite so any additional twisting once cured will break the loctite bond. Yes? No?
  21. Jun 9, 2023 at 6:17 AM
    metalpete
    ID
    Just a habit after replacing/reinstalling parts after X amount of miles. They die hard, you know...
    Bolt came out relatively easy. Used a locking needle nose vice grip, taped the ends to try and save the teeth and worked her back and forth. Got to a point where the cv was in the way, so I cut as much as I could with the Dremel before getting the a bolt cutter in there. Cleaned the hole as best I could, worked the new bolt in gently, and we're good to go.
  22. Oct 13, 2024 at 9:54 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Here's a thought... 59x .2 =11.8. 59-11.8= 47.2.
    Maybe they just rounded up to 48, forgot to put a fpn indicating that the 48 is for bolts with loctite on them from factory or added. And this is the start of all of the confusion, they printed it forgot something or we're not seeing something notated in the manual as to which is for which situation. For the '05-'06 anyways.
    shifty` likes this.
  23. Oct 13, 2024 at 10:10 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thought I saw a thread listing all the different lbj bolts and torque values
  24. Oct 13, 2024 at 11:41 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    More or less:
    https://www.tundras.com/threads/spiker-engineering-lower-ball-joint-bolt-test-1st-gen.111746/
    "00-01(02-04 no protector) OEM "green" bolt PN 9008010066 Torque to 59ft-lbs (SINGLE USE BOLT ONLY)
    00-03(04) ARP bolts (stronger but higher cost) 663-1004
    00-03(04) "Black" bolt for use with protector only 9011910933 Torqued to 37ft-lbs
    04-06 PN 9010512316 Torqued to 59 ft-lbs according to @shifty`. Spiker states up to 80ft-lbs is also ok."
  25. Oct 13, 2024 at 11:45 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks that is the one I saw, spiker also did it on the 3rd gen 4runner forum
  26. Oct 13, 2024 at 5:14 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    bringing back a thread from 2 years ago.
    But. Video i watched has the 4 bolts at 47 ft lbs.
  27. Oct 13, 2024 at 5:25 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Yeah man, I get it. I mistakenly posted in this instead of the spiker test initially. I figure it can't hurt being as it's probably the main safety concern people have with these trucks (aside from a Rusty frame snapping in half) and for good reason. A lot of confusion about this in general.
    Weagle likes this.
  28. Oct 13, 2024 at 6:30 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    This all has me concerned (again) about my wheel studs
    I had to get onto the shop that did my tires and alignment. I told them each time they should be torqued to about 85 to 89 ft/lbs. and yet every time I checked behind them I could tell they were easily over 100 probably at about 120 ft/lbs
    the last time they told me they told me they bought a torque wrench and would torque them to my specifications. But like I told them I was worried about the stress and possible stress fractures
  29. Oct 14, 2024 at 2:49 AM
    It varies based on bolts and the bolts vary based on year. Know which fastener you’re installing, and torque based on fastener spec versus some video which may or may not match your year or bolt!
    Hi06silver likes this.
  30. Oct 14, 2024 at 4:43 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Since this thread has been brought back up, it appears OP was using the "black" bolts to be used with the protector that are supposed to be tightened to 37 ft-lbs and not 59 so I guess it makes some sense that they would break.
    shifty`, KNABORES and Hi06silver like this.
