low range issue
Discussion in '1st Gen Tundras (2000-2006)' started by toyotapete, Mar 8, 2016.
  1. Mar 8, 2016 at 12:22 PM
    toyotapete
    toyotapete [OP] New Member
    2004 Tundra extended cab 4x4
    7'6" snow way plow
    Have a 2004 Tundra, 167000 miles. I can't get it into low range. I get a light and a beep but it won't set into low. Hoping there is an external switch somewhere under the truck I can clean and lube but I haven't crawled un der there to look yet.
    Thnaks First time post
  2. Mar 8, 2016 at 12:25 PM
    Welcome.
    Are you completely stopped, in neutral? I would also take a look at ur actuator.
  3. Mar 8, 2016 at 12:27 PM
    Mike Tread lightly.
    south carolina
    Welcome. Nothing under the truck you can do for a switch.
    Does it engage 4wd in high normal any strange sounds?
    Are you putting the transmission in neutral when shifting to 4wd low?
  4. Mar 8, 2016 at 12:39 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    Have you tried moving a little and trying again?
  5. Mar 8, 2016 at 7:02 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    you need to be stopped and the trany in neutral, after switching to 4lo put the trany in gear. thats how my 2000 tundra works
    Black Wolf likes this.
  6. Mar 11, 2016 at 5:17 AM
    toyotapete
    7'6" snow way plow
  7. Mar 11, 2016 at 5:19 AM
    toyotapete
    7'6" snow way plow
    Going to neutral did the trick. I guess looking at my owners manual would have told me that but I misremembered it had to be in park HA. It's great to have a place to go to get help on simple and not so simple questions.
    Thank sall.
