Low oil pressure
Discussion in 'General Tundra Discussion' started by Patrick03, Dec 19, 2023.
  1. Dec 19, 2023 at 2:56 PM
    Patrick03
    Patrick03 [OP] New Member
    2004 Tundra
    I have a 2004 Tundra that reads the same oil pressure as the one displayed from the post dated 2022 which at idle is almost nothing. It raises on acceleration and maintains above 1/2 to 3/4 while driving. Repairs if necessary??
  2. Dec 19, 2023 at 4:45 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  3. Dec 19, 2023 at 5:29 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Common problem reported in FGT discussions. Toyota upgraded the sending unit to one with larger diameter hole in threaded section. Probably what I’d do first. Might also consider hooking up a mechanical gauge to measure actual oil pressure.
    The Black Mamba likes this.
  4. Dec 21, 2023 at 10:37 AM
    OverSquareEng
    OverSquareEng New Member
    2006 Sequoia Limited 4WD
    It's almost always a faulty oil pressure sending unit. Not actually low oil pressure.
  5. Dec 21, 2023 at 10:49 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Very common. Mine reads almost none at idle and about 1/4 at 3k rpms. Don't let it bother you.
