Low oil pressure even after an oil change
Discussion in '1st Gen Tundras (2000-2006)' started by Gman0613, Mar 4, 2024.
  1. Mar 4, 2024 at 5:12 PM
    Gman0613
    Gman0613 [OP] New Member
    2006 limited
    None
    I have a 2006 tundra limited that the oil pressure stays above the first line on the gauge, even after I changed the oil? No noises from the engine?
    thanks
  2. Mar 4, 2024 at 5:37 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Normal. Should increase under load and increase in RPM. This is assuming you have the 4.7. Can't speak for V6.
    FrenchToasty likes this.
  3. Mar 4, 2024 at 5:38 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  4. Mar 4, 2024 at 5:39 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    ^^^^READ THIS^^^^
