Low idle like 500 sometimes it’s flutters .
Discussion in '2nd Gen Tundras (2007-2013)' started by gilles, Nov 14, 2024.
  1. Nov 14, 2024 at 4:30 AM
    gilles
    gilles [OP] New Member
    Gilles
    2010 Trd 5.7l
    I just want it to run for ever
    So I lost my ac I think it has somthing to do with it could this be . i am bad at tracking these things I am wondering if I should just buy a new ac unit the clutch went on mine been putting it off but seems to be multiplying with little problems .
    It’s weird cause the idle seems to mess with voltage . i am going to attempt throttle body clean but I see lots of guys say it’s not a thing ?
  2. Nov 14, 2024 at 5:21 AM
    Post is a bit confusing, But the low or erratic idle could be a vacuum leak. Idle will mess with voltage as the alternator has to spin fast enough to create it. Cleaning a throttle body is a real thing. Get some throttle body cleaner, take the intake hose off, and wipe the throttle body plate off with the cleaner, don't spray into the throttle body. Don't let the plate slam shut.
  3. Nov 14, 2024 at 6:49 AM
    gilles
    Gilles
    2010 Trd 5.7l
    I’ll give it a try . Sorry … half French .
    Thought u would throw in the a/c quitting to see maybe a connection .
    but my truck somtimes stalls when I start it jumps to like 12-15 hundred rpm then does check engine and at temp light come on . If I take keys out and lock doors it seems to start up fine every-time …
    But now my idle seems low like 500 and was jumping …
    My ac went last summer I have to shut it off if my fan pops on , this seems to regulate it . I will clean throttle body and new air filter also going to order ac unit stop putting it off .
    I will go from there . Thanks for the help .
  4. Nov 14, 2024 at 7:25 AM
    If your AC compressor is known to be bad, why not isolate it by getting a belt that bypasses it until you decide to replace it?
  5. Nov 14, 2024 at 9:00 AM
    gilles
    Gilles
    2010 Trd 5.7l
    My buddy said to pull the wire it will act just like a pulley I will order the unit and get a regen . Try that . Also throttle body clean up .
    She needs a little love .
    I’m a pipe fitter not a mechanic
    Keep you posted but honestly thanks good forum !
  6. Nov 14, 2024 at 3:49 PM
    gilles
    Gilles
    2010 Trd 5.7l
    So I pulled the cable to my ac it had not filtered since . Ordered new ac unit and air filter also will remove my throttle body to clean it this weekend .
    KNABORES likes this.
  7. Nov 15, 2024 at 5:14 AM
    gilles
    Gilles
    2010 Trd 5.7l
    I pulled the wire for my a/c unit . And boy howdy . My truck has had good starts and seriously my idle smoothed right out still want to clean my throttle body . ‍♂️
    I just pulled the wire on the side through my driver side wheel well .
  8. Nov 15, 2024 at 5:28 AM
    So your AC clutch was stuck on?
  9. Nov 15, 2024 at 6:52 AM
    gilles
    Gilles
    2010 Trd 5.7l
    Yeah it’s like no matter what it would engage and was overheating.
    I found a replacement on parts avatar .
    But it looks like a contract to change
