Low fuel light
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Nflguy, Aug 18, 2023.
  1. Aug 18, 2023 at 12:54 PM
    Nflguy
    Nflguy [OP] New Member
    I have a 2021 TRD Pro
    How far can you drive once the low fuel light comes on? The low fuel light turned on right as I got in a long line for pick up at my kids school. It’s 110 degrees and I’m worried I’ll run out of gas waiting in line for 20 minutes with the AC on. Am I being paranoid?
  2. Aug 18, 2023 at 12:57 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    You’ll be fine. There’s at least a 6-gallon reserve. But you don’t want to run it that low regularly - the reserve is intended to keep the fuel pump cool. I’d say pick the kids up and then head to the gas station.
  3. Aug 18, 2023 at 2:29 PM
    Blue Thunder
    Washington
    The truck burns about .5-.6 gallons per hour at idle. Maybe a bit more if your A/C is running hard full time. You'll be fine. Get thru the line and find a gas station.
  4. Aug 18, 2023 at 2:52 PM
    Nflguy
    This is the first time that I’ve ever let it get to the point of having the low fuel light come on. We went straight to the gas station and put in 31 gallons!
  5. Aug 18, 2023 at 7:14 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    I once (and only once) put in almost 31gal after driving about 30-35 miles past the light coming on… Enjoy!
  6. Aug 18, 2023 at 7:24 PM
    Nflguy
    When the low fuel light came on we were less than a mile from the gas station.
