Loud howling noise in rearend
Discussion in '2nd Gen Tundras (2007-2013)' started by Yoyogurl, Dec 16, 2018.
  1. Dec 16, 2018 at 3:13 PM
    Yoyogurl
    Yoyogurl [OP] New Member
    2008 toyota tundra 4x4
    I have very loud howling/whining noise from rearend. but it is only when under load. With foot off accelerator there is not noise at all, but under any load it makes a fairly loud humming/wining noice. Doesn't seem to make any difference if I swerve one way or another and transfer the weight from side to side. Also makes noise in four wheel, didn't really use it just checked to see if noise would improve.
    Put truck on the lift. With husband pushing pressure on the driveshaft, it seemed to quiet and almost completely stop. So we changed carrier bearing, no help at all!
    PLEASE help. I really want to know any suggestions bef ore I have to buy driveshaft or rearend!
  2. Dec 16, 2018 at 3:31 PM
    koditten
    Kirk
    Midland of the Mitten
    Wheel bearing?
    Les7311 likes this.
  3. Dec 16, 2018 at 3:38 PM
    tmart
    tmart New Member
    Travis
    Uh sounds like the rear diff
    OR18TRD likes this.
  4. Dec 16, 2018 at 3:58 PM
    koditten
    Kirk
    Drain and change gear lube. If you got lots of big metal shavings, then it's a good chance the diffy is bad.
    OR18TRD and driverdog like this.
  5. Dec 16, 2018 at 4:02 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Doesn't sound like when my diff went bad. Mine made noise on deceleration and when I put it on a lift and put the truck in drive at idle (professionally done on closed course, do not try at home) I could hear it clunking.
    Can you explain more about how pressure was placed on the shaft to make the sound go away? Was the truck in drive? How was pressure applied?
    15whtrd likes this.
  6. Dec 16, 2018 at 4:03 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    That's what she said
    15whtrd likes this.
  7. Dec 16, 2018 at 4:06 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'll admit, the Beavis and Butthead in my mind woke up when reading the subject line. I could hear Beavis giggling.
    15whtrd likes this.
  8. Dec 16, 2018 at 4:08 PM
    15whtrd
    15whtrd Mr. Blonde
    All this. My experience has been the same with a diff going bad.
    Also you should not be turning on a dry street in four-wheel-drive. But you should be exercising the 4 x 4 monthly.
    Next cheapest step is grease the Ujoints if they have the fittings for it, or replace. Even if that’s not the problem, at least you know you can rule it out.
  9. Dec 16, 2018 at 5:06 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    :worthless:
    driverdog likes this.
  10. Dec 16, 2018 at 5:25 PM
    BIGUGLY
    Paul
    2018 Limited
    If you can make the noise appear and disappear by feathering the throttle it's most likely a pinion bearing.
  11. Jan 16, 2019 at 7:30 AM
    Punisher5353
    Punisher5353 New Member
    Pennsylvania
    2013 Black Tundra CrewMax TRD
    JBA Long Tube Headers, X pipe, Duel Borla Exhaust, Air Box Mod, Dap Tune, 22” Black Rhinos
    WOW!!! I was just saying the noise I’m hearing I can feather the throttle and make the noise come and go.
  12. Jan 17, 2019 at 3:52 AM
    Dr_Al
    Dr_Al New Member
    Al
    Check the fluid level in the rear diff. It's easy to do. Just remove the fill bolt on the back cover and you should be able to put your finger into the hole and touch the oil. If not then try to find something clean, like a piece of electrical wire that you can put one end into the hole and see how far down the oil is from being full. Usually bearings inside it don't go bad unless your oil leaked out. If it is low then add some cheap gear oil to fill it up and see if the noise changes. Until you are sure that the diff isn't the issue I wouldn't spend much money on good oil that you could be draining right back out again. If adding oil makes the noise change then you know what the problem is.
  13. Jan 17, 2019 at 4:23 AM
    Punisher5353
    Pennsylvania
    I changed the Rear diff oil and the noise stayed the same. I do admit that the old oil was thick and creamy. The level of the oil was good before changing. I just though it was weird that the sound I’m hearing that I could make the sound go away by feathering the throttle. It’s not a loud noise but kind a like sandpaper rubbing back-and-forth.
  14. Jan 17, 2019 at 4:41 AM
    Dr_Al
    Dr_Al New Member
    Al
    When you say creamy are you talking the color? White or pale green colored oil usually indicates water has mixed in with the oil.
  15. Jan 17, 2019 at 5:43 AM
    Punisher5353
    Pennsylvania
    It’s was very light brown and the last of the oil had foam that had came out. I used a paint strainer to see if there where any Metal shavings and only found one very small piece. My friend that has a Tacoma we where doing the oil diff change the same time said wow, That diff oil has never been changed. I picked the truck up used @ 50,000 and I’m @ 100,000 when I changed the diff oil.
