Loud howl above 70 mph, but only when on the gas
Discussion in '1st Gen Tundras (2000-2006)' started by chester, May 10, 2021.
  1. May 10, 2021 at 11:31 AM
    chester
    chester [OP] best member
    2005 Double Cab SR5
    The sound seems to be coming from right under the middle of the truck. It starts at 70 mph and continues to 80, which is the fastest I've tried. In that 70-80 mph range, the howl only appears when I'm on the gas. I don't need to be accelerating; just cruising at a constant speed induces the howl. If I let off the gas, the howl disappears.
    When I downshift from 5th to 4th at a constant speed, the howl doesn't change at all. Same pitch and volume. That tells me that it's something after the transmission (u-joints, spicer bearing, differential). Is that a correct conclusion? What are my next steps toward diagnosis?
    Truck is 2005 DC 2wd with 227k miles. I've had this truck for a year and around 3k miles, and I don't have any service history for it.
  2. May 10, 2021 at 11:42 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    If you can get it on video and post it here. That be very helpful.
  3. May 10, 2021 at 12:02 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Sounds like rear end/gears. Check your rear diff fluid level and for leaks.
    chester[OP] and FrenchToasty like this.
