Loud clunk when shifting out of 4wd high
Discussion in '2nd Gen Tundras (2007-2013)' started by ktrout, Nov 8, 2019.
  1. Nov 8, 2019 at 11:38 AM
    ktrout
    ktrout [OP] New Member
    2012 4.6 4WD
    2012 4.6 4wd 66K miles. Following the manual's instructions, I usually drive in 4 wheel high for approx 10 miles on straight dry road. Never a problem until last 3 times. No noise shifting into 4 wheel high, but LOUD clunk shifting back to 2wd. Happens at 10 mph or 50 mph. Truck hasn't been off road in 4wd for a year.
  2. Nov 8, 2019 at 1:04 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Can you feel the clunk?
    Does it feel or sound like it's coming from the transfer case or front differential?
    When was the last time you've changed the oil in the transfer case or front diff?
  3. Nov 8, 2019 at 1:21 PM
    ktrout
    2012 4.6 4WD
    Can definitely feel the clunk, I believe from the front. Oil in transfer case & front diff has never been changed.
  4. Nov 8, 2019 at 3:00 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Then I would start by servicing both of those.
  5. Nov 8, 2019 at 3:15 PM
    15whtrd
    15whtrd Mr. Blonde
    All your tires are the same size age and manufacture? Psi is where it should be?
    koditten likes this.
  6. Nov 8, 2019 at 4:57 PM
    timsp8
    NY
  7. Nov 8, 2019 at 5:04 PM
    koditten
    Kirk
    Midland of the Mitten
    This. If all tires are not same diameter, you WILL get a loud clunk.
    15whtrd[QUOTED] likes this.
