loud clunk noise when making a sharp left turn, 2005 4x4 DC
Discussion in '1st Gen Tundras (2000-2006)' started by chris, Dec 12, 2019.
  1. Dec 12, 2019 at 4:41 PM
    chris
    chris [OP] New Member
    I have been to three different mechanics and this problem is still not solved. First two said nothing was wrong, and the last one got me for new CV joints. Truck is still making the sound. I'll just have to keep investigating I guess. Has anyone had to replace the lower ball joints on their 1st gen. Could this possibly be the cause of the sound?
    Can anyone please point me in the right direction if they have had this problem
  2. Dec 12, 2019 at 4:45 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Make sure your alignment cams are torqued.
    revtune and NewImprovedRon like this.
  3. Dec 12, 2019 at 5:18 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Damn, I’ve got a clunk type thing going on to. It could very well be loose alignment cams, I had that happen on my tacoma, drove me nuts. It could also be bushings; sway bar, steering rack or lower control arm.
  4. Dec 13, 2019 at 5:07 AM
    TurdFerguson
    TurdFerguson New Member
    Waynesboro, Virginia
    2000 TUNDRA SR5 AC 4x4 V8
    2002 TUNDRA SR5 AC 4X4 V8 TRD
    While replacing both CV axles, my mechanic noticed and replaced bolts missing from BOTH lower ball joints. Two bolts were missing from each one! All the noise, clunking and looseness went away once new bolts were installed.
    bmf4069 and revtune like this.
