Loud Clunk / Driver side front when wheel turned all the way
Discussion in 'Suspension' started by Snookemjoe, Nov 8, 2023.
  1. Nov 8, 2023 at 6:58 PM
    Snookemjoe
    Snookemjoe [OP] New Member
    2012 Silver Tundra Crew Max TRD
    Tonneau Cover, Tint, Window Visors
    My 2012 Tundra has a very loud noise when the wheel is turned all the way to the right. Clunking / Popping sound. Does anyone have an idea of what this could be ?? Thanks , Joe
  2. Nov 8, 2023 at 7:03 PM
    Steering rack? Tie rod end? Is it 4WD? Could be CV joint? Need more info abut your setup to say but at 11 years old, something could just be wore out.
    Snookemjoe[OP] likes this.
  3. Nov 8, 2023 at 7:10 PM
    Snookemjoe
    It is not 4 wheel drive. I had the struts replaced about a month ago. I’ll look at the cap bushing tomorrow. Only happens when I’m turning hard into a parking spot or just a tight turn. Thanks
  4. Nov 8, 2023 at 7:12 PM
    Struts replaced a month ago is the kind of thing to include so people here can better help you out. I would start with those. What kind of struts did you have installed? Did you do the work yourself or a shop? Someone should check the bolts and ensure they are torqued properly.
  5. Nov 9, 2023 at 7:01 AM
    Snookemjoe
    Struts we’re installed by my mechanic. I am contacting him about the sound. Was just wondering what could cause that clunk. Thanks
  6. Nov 9, 2023 at 7:18 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I had a sway bar end link snap after suspension work on a previous car. It would make a couple loud clunks pulling into a parking lot or driveway with any elevation from the road and with the steering cranked. I completely missed it when I had it jacked up with the wheel off because I kept looking for something loose on the new suspension parts. Just a thought.
  7. Nov 9, 2023 at 7:30 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Check if your brake caliper bolts are tight.
  8. Nov 11, 2023 at 12:37 PM
    Snookemjoe
    Looked at the struts and cap bushing is new as both were just replaced. Nothing jumps out as worn or broken, loose. Haven’t had a chance to go by mechanics shop. Maybe struts are catching on something. Will post after seeing mechanic.
