Lots of codes
Discussion in '1st Gen Tundras (2000-2006)' started by driver, Jun 16, 2022.
  1. Jun 16, 2022 at 5:48 PM
    driver
    driver [OP] New Member
    My son bought a2006 Tundra with a 4.7 motor, he bought it off lot and it's been a good truck for the last couple of years for having 225000 miles on it. The other day it started missing a little so I ran the codes on it and came up with p0011,p0021,p0018,p0016 and some misfire codes,0300,0302,0308. The thing starts great at idle, no misfire as soon as soon as you put a little gas to it the misfire codes start. I've checked the wiring,camshaft oil control valve, crankshaft sensor and the camshaft sensorl you know the easy stuff. Have no idea how long the timing belt has been on it but it looks like the next move. Never had a Toyota but heard nothing but good things. Anybody got an idea what might be going on,Thanks
  2. Jun 16, 2022 at 5:55 PM
    Welcome to the site.
    Lots of knowledge from these guys in the best gen section.
    tunyota likes this.
  3. Jun 16, 2022 at 6:49 PM
    I'm going to take a wild stab at this and say you need to check the crank position sensor harness to make sure a pulley didn't clip it.
    It's not uncommon for that wire to get nicked or severed if not properly secured after working on the timing belt, water pump, or both. (example of how to tuck below driver's side cam cover if not routed properly)
    You may also want to consider testing the sensor.
    sportbike37 and tunyota like this.
  4. Jun 16, 2022 at 7:39 PM
    driver
    The wires looked good from what I could see, that whole area hasn't been messed with since we've had it, I did pull the crankshaft sensor out put a multimeter on it to check resistance and it showed to have the about the same as the camshaft sensor I'm not real handy with electric but with it set on one of the ohm settings it seemed to show some.
    tunyota likes this.
  5. Jun 17, 2022 at 5:58 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    maf sensor, fuel pump or timing issue?
  6. Jun 17, 2022 at 6:53 PM
    driver
    With all the camshaft and crankshaft sensor codes I'm leaning towards timing issue but I'll do some more checking, it would be nice to find it was something simple
  7. Jun 17, 2022 at 7:45 PM
    Next thing I'd do would be popping off one of the timing covers and inspecting the condition of the belt.
    If it looks brand new, I'm guessing the timing is possibly off? If you're correct and there's no rodent damage or rub to wiring, and you tested the crank position sensor (per the FSM, not the test you've written above) then that's where I'd go next.
    There are copies of the FSM on this site. You may want to grab one, pick a spot to dive in on diagnostics, and run with it.
  8. Jun 17, 2022 at 9:11 PM
    gascap
    gascap New Member
    2002 Tundra
    Maybe a fuel injector or a coil. Unplug a coil one at a time to see if the engine runs rough or same. If one is the same then that coil or wire has a problem.
    tunyota likes this.
  9. Jun 17, 2022 at 9:53 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    Welcome @driver :cheers:
    Just curious if you happen to know:
    1. When was the last oil change?
    2. Is the oil level within acceptable ranges?
    3. Is the oil pressure gauge showing acceptable ranges during idle and under load?
    4. Does it consume much oil between changes?
    5. Have the spark plugs been replaced in the last 30-60k miles?
    Consider numbering the ignition coils and swapping them around to see if the other cylinders misfire.
    Found these resources you might find helpful:
    https://f01.justanswer.com/indy-tech/1a0da677-ecfd-48f9-8e40-5da111c92c1f_P0011.pdf
    https://f01.justanswer.com/indy-tech/eaaff3ad-bb68-4783-9827-a962b56ef1ae_P0018.pdf
    Also, I would suggest getting a copy of the TechStream software if you don't already have it. https://www.youtube.com/results?search_query=techstream+toyota
    https://www.youtube.com/watch?v=vDElMyfDxg4
    https://youtu.be/KDpldAv0uQE
  10. Jun 18, 2022 at 4:38 AM
    driver
    Thanks for all of the good suggestions and a lot of investigating to do, the oil has been changed when it should be, plugs kinda like the belt,no idea, the thing that throws me is clearing of the codes, starting it up it has the codes for camshaft crankshaft out of whak idle it up then you get the misfire, I'm thinking I might not be testing it right, more reading up on it.Thanks All
  11. Jun 18, 2022 at 7:43 AM
    You know you can carry your vehicle in for diagnostics at any dealership, right?
    I've done this more than once. Carry it in, have the pros diagnose it, then take the vehicle after. They'll charge you an hourly rate (for me has typically been 1-3 hours). Let them come at you with a repair quote, you have your laundry list of things. Chances are it's going to be really f'n expensive because it's a dealership. "Jeez, that's high. It's not in the budget now, but I'd prefer you guys work on it. How long is this quote good?" and go on your way.
    In difficult cases like this, it clears a hell of a lot of guesswork. Solid chance the OEM dealership certified mechs are going to get it right. I think the only one of us that's certified here is empty_lord.
  12. Jun 18, 2022 at 8:21 AM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    I don't know if "certified" is what it used to mean. I see a lot of certified people who might be good at specifics, but have trouble thinking outside the box. Im not talking just mechanics either.
  13. Jun 18, 2022 at 8:29 AM
    driver
    That's an option I was looking at the local dealership said their price would be about 1250.00 if it didn't need a water pump or anything else, I believe your right they would know what's going on. We are almost 60 miles to nearest dealership,so with the misfires and not knowing whats going on it would be a couple of hundred to get towed down there and the same back, it's a spare vehicle right now so I have plenty of time to check out more options before pulling the trigger on that one
    shifty` likes this.
  14. Jun 18, 2022 at 9:40 AM
    Oh believe me, I work in the tech/security sector, well into my 3rd decade now. You're preaching to the choir on that one. :rofl:
  15. Nov 8, 2022 at 11:35 AM
    driver
    Hello again, I still have the misfire problems with the Tundra but i've done a little to it this summer when it wasn't too hot. I checked on prices for the sensors, fairly cheap so I changed out the crankshaft sensor, no change, got one camshaft sensor, changed out one side, no change, switched to other side, no change then both oil control valves, no change, then found a local mechanic shop that does that kind of work, they put a scope on the wiring showed to be firing ok, called to get the ok for a timing belt change, they pulled the camshaft gear covers and set the crankshaft where it was supposed to be, looked good, and the belt looked good, they had no idea so I had it towed back home. That was about a month ago I had heard of the ocv filters or screens can sometimes foul things up, I think they are in behind the ac compressor and alternator on other side but wanting to make sure before starting. Sorry for the long-winded rundown, almost forgot been starting it up and letting it run every week or two, I let it run for about ten minutes while I cleared out enough to get it in the garage when I tried to pull it in it wouldn't even untrack itself, waited a couple days started it up still had the misfire but pulled in no problem? Thanks for the patience.
  16. Nov 8, 2022 at 12:38 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    Fuel filter, fuel pump, maf sensor?
  17. Nov 8, 2022 at 2:16 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    “Certified” in the tech sector is dated.
    Proper terminology today is SME (subject matter expert). Get with it. lol
    Not that it means anything different.
    shifty`[QUOTED] likes this.
  18. Nov 8, 2022 at 2:20 PM
    That's where I'm going next. Something related to fuel/oxygen/spark
    Like, spark plugs, fuel pump, (it's never the fuel filter), fuel pressure regulator, O2 sensors, MAF, something that would cause the the ECM to not know how much air/fuel was going into the cylinder, and therefore wouldn't mix right, causing potential misfires.
  19. Nov 10, 2022 at 11:17 AM
    driver
    I thank you guys for all the recommendations I cleaned and checked the MAF I had to replace O2 sensors on a 98 f150 a couple of years back, but it showed the codes for that, I'm still stuck on all the codes for camshaft and crankshaft problems. If it was a sparkplug or something with the gas, would the thinking be that that would cause the misfire and then that would cause the codes from original post?
  20. Nov 10, 2022 at 12:01 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    Yes
  21. Nov 10, 2022 at 12:20 PM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    Codes don't always tell you what is happening. They tell you what the computer thinks is happening. Do the simple stuff first. An engine that idles but won't accelerate is a classic clogged fuel filter symptom. This can lead to so little fuel making it to the combustion chamber that the computer thinks something else is happening. At 225k miles, changing the filter is probably good mojo anyways.
    Aerindel likes this.
  22. Nov 10, 2022 at 1:02 PM
    On 1st gens, the fuel filter has literally never, ever, ever been anyone's problem. And it's a complete and total bitch to change. Lots of people have replaced it thinking it was the problem, and replacing it solved exactly zero issues to date.
    After the wild results my low-mile Gen1 saw, I'd recommend cleaning the MAF with some CRC MAF Cleaner spray. The German Toyota mechanic has a good video covering the "how" if it's interesting :D
  23. Nov 10, 2022 at 4:29 PM
    driver
    I had some CRC MAF cleaner and used it when I pulled it out, I was watching 2 ways to check with a multi meter and letting it idle and unplugging the MAF and seeing if it dies the problem is somewhere else, mine died but that may not be the proper way to check it, I'm going to try to find that German Toyota video. Dropping the tank and changing the filter might be the next move I guess crossing it off the list think with that many miles it's bound to have had some bad gas in poured in it.
  24. Nov 10, 2022 at 5:19 PM
    I can't say this enough: It's never the fuel filter. And in your 2006 it won't be, because the 2005-2006 don't have one.
    Everyone here that's ever changed their fuel filter will tell you: It's a total bitch to replace, and you'll take plenty of gas to the face, and risk damaging lines. I didn't believe it after the 5th or 6th complaint, and I went to check mine, and I sure as hell wouldn't want to replace it. There's already a screen on the tank to filter out big shit on these trucks. The on-framerail filter is a secondary filter. This isn't a GM, a Ford, or a Dodge. It's never the fuel filter.
    But if you plan on dropping the tank, you may as well proactively buy a new DENSO fuel pump and swap it (dont buy it on scAmazon or fleaBay, they often sell counterfeits) because it's very possibly the fuel filter. Use DENSO part finder on this page to find the right part #: https://www.densoautoparts.com/
    I missed the 'misfires when you give it gas' symptom. That makes me wonder if it could throttle position sensor, or throttle assembly too. But at 225k miles, fuel pump going out wouldn't be unheard of. I don't expect anyone to have fuel pressure gauges, but dropping one in line is easy enough, just to see if your fuel pump is having trouble keeping up.
    Here's that video, @driver - This Toyota-Maintenance channel is great, he's always deliberate, clear, with a good pace, takes time to explain and walk you through "why" and "what". Yes, he's not working on a 1st Gen here, but this is the same process I follow. Any time I'm doing anything new on a brand or platform I've never worked on, I also hit up a couple of videos to make sure there's no "gotchas" I might hit along the way.
  25. Nov 10, 2022 at 7:50 PM
    driver
    Good video looks like he is pretty thorough, the thing will start misfiring just idling just faster when you give it the gas.
  26. Nov 11, 2022 at 5:36 AM
    Since it only takes 5 minutes to do, I'd also pull and take a couple pics each of the 1st and/or last spark plug on the passenger side (skip the middle two) and attach them here. Those are what's tossing p0302 & p0308. It'll also allow us to eliminate the plugs (either old plugs, or wrong plugs, or fake plugs) as the problem. I presume you still have the OEM coil packs on there, or are you not sure?
    Toyota calls for a specific Iridium long-life spark plug for VVTi engines like the V8 in the '05-'06, and there's been so many cases of people buying counterfeit spark plugs off scAmazon and fleaBay and it either nearly destroying their engine or causing stupid issues like this, it's not funny. Like, the legitimate iridium plug installed at the factory should last you 100k miles easily, I just changed my factory plugs at 73k miles, they still have plenty of life left, if you're near Atlanta I'm happy to drive 'em over if you want 'em :D
  27. Nov 11, 2022 at 6:32 AM
    driver
    I'll be checking the plugs and see how bad off they are brand and such hopefully today, we're about 700 miles west of you but I do appreciate the offer.
  28. Nov 11, 2022 at 12:11 PM
    driver
  29. Nov 11, 2022 at 12:13 PM
    driver
    First time sending pictures sorry too many
  30. Nov 11, 2022 at 12:16 PM
    driver
    If I can't find my gauge I'll have to pick one up
