Lost oil/ Nitrogen
Discussion in 'Suspension' started by motod6, Mar 19, 2019.
  1. Mar 19, 2019 at 8:59 AM
    motod6
    motod6 [OP] New Member
    David
    2015 White TRD
    I had a loose fitting on a brand new fox. I feel like 4 wheel parts did something but I did the install so ultimately it's my fault. I checked the fittings prior and completely missed this shock. If I had to guess I'd say it lost a 1/2 oz of oil or less.
    Am I ok with just adding nitrogen or am I going to need oil as well? Not sure oil capacity on these (fox 2.5 CO). I'm in a time crunch and would like to take the truck somewhere rather than pull the shock and take it.
    Any recommend shops? Preferably close to Costa Mesa or Yorba Linda
  2. Mar 19, 2019 at 9:30 AM
    15whtrd
    15whtrd Mr. Blonde
  3. Mar 19, 2019 at 9:55 AM
    Charge it with N2. You will be fine.
    15whtrd and HappyGilmore like this.
  4. Mar 19, 2019 at 9:56 AM
    motod6
    David
    2015 White TRD
    15whtrd likes this.
  5. Mar 19, 2019 at 10:27 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so, my 3.0 is still dripping. very slight but, there's a mark on the driveway. i'm headed up to filthy on thursday to drop off the 2.5s for a rebuild. should i have them hit with some N2 while i'm there? what do i need to do this at home?
    TheBeast likes this.
  6. Mar 19, 2019 at 10:44 AM
    If your leaking enough on the 3.0’s to have oil dripping, they need a re-Seal.
    smslavin likes this.
  7. Mar 19, 2019 at 10:48 AM
    blizz86
    blizz86 New Member
    Just wondering if you found a shop that checked/charged your N2? Im located near you so i wanted to check as well.
  8. Mar 19, 2019 at 10:52 AM
    motod6
    David
    2015 White TRD
    I haven't yet
  9. Mar 19, 2019 at 10:57 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I'm pretty sure Costco has nitrogen fill station for free if youre a member. Bring an accurate gauge with you and see if you can fill em yourself.
  10. Mar 19, 2019 at 10:57 AM
    blizz86
    blizz86 New Member
    Its a totally different system between shocks and tires.
  11. Mar 19, 2019 at 10:59 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    that's what i figured. i'll be grabbing a seal kit and oil from filthy.
  12. Mar 19, 2019 at 11:02 AM
    HappyGilmore
    Trent
    Lakewood CA
    What are you talking about specifically? It does need a higher pressure, so the tire station might not go that high. As long as the shock has a Schrader valve it can be filled.
  13. Mar 19, 2019 at 11:20 AM
    TheBeast The Beach
    motod6[QUOTED][OP] likes this.
  14. Mar 19, 2019 at 11:53 AM
    blizz86
    blizz86 New Member
    you'll need a no loss valve as the shock has very little n2 volume under high pressure and you'll also have to jack the truck up so that the shock is not compressed at all. Never seen a tire shop that allows customers to bring in their own adapters.
    HappyGilmore[QUOTED] likes this.
  15. Mar 19, 2019 at 12:02 PM
    HappyGilmore
    Trent
    Lakewood CA
    Yeah, i forgot about jacking the truck up, youre right. I would think the no loss adapter wouldnt be too obvious since you just attach it to the shock valve and fill from there.
    Most weekend warriors probably dont have an adapter. Id think in a pinch he can do it with out the no loss set up, may not be perfect. I was just trying to make a suggestion if he couldnt get into an offroad shop. He noted that he was in a time crunch.
    motod6[OP] likes this.
