Losing coolant
Discussion in '2nd Gen Tundras (2007-2013)' started by Mainetundra, Jan 17, 2017.
  1. Jan 17, 2017 at 6:11 AM
    Mainetundra
    Mainetundra [OP] New Member
    08 Tundra 5.7L SR5
    Hello everyone.
    I have a 2008 Tundra SR5 with a 5.7L V8. I have been losing coolant . It takes a few weeks go drain out but there is nothing visible under the truck. Friend told me it might be leaking through the head gasket .Has anyone encountered this before ? Thank any and all help.
  2. Jan 17, 2017 at 6:29 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    if it's leaking through the head, you'll either get white smoke in your exhaust (enough so that you'd notice) or your oil will look like milkshake depending on whether it's leaking into the cylinder or water jacket. (or both) If none of the above... read below.
    head to advanced, and take advantage of their tool rentals and i'd look for a coolant pressure test so that you can pressurize with the engine off... you may possibly be able to hear it leaking and look for it. Failing that, get a leakdown tester and check each cylinder for leakdown - when you get the results from that, post them back here and we can help you figure out next steps.
    Other random thoughts... any moisture inside the truck? an ex of mine had a ford that had a coolant leak inside the car for the heater... that sucked.
    ColoradoTJ and Mainetundra[OP] like this.
  3. Jan 17, 2017 at 6:30 AM
    Ericsopa
    Ericsopa Old man and the sea
    My son has an '07. Had the same problem. I found the leak in the radiator on the seam between the core and the top plastic tank. Such a small leak that the water evaporates/boils off before there are any tell-tale drips on the ground. He hasn't replaced the radiator yet, just keeps topping it off, since the loss is so gradual. But my point is, I think you'll find the leak if you look closely. Dried reddish deposits/stains are the evidence (if you're using that color antifreeze). I think a small external leak is more likely than a head gasket leak.
  4. Jan 17, 2017 at 1:59 PM
    Mainetundra
    08 Tundra 5.7L SR5
    Thanks guys . Il look into those . Be well.
  5. Jan 18, 2017 at 7:24 AM
    Mainetundra
    08 Tundra 5.7L SR5
    Turns out it was the water pump. Doesn't leak all the time but as soon as you let the truck run for a few minutes and shut it off it drips right out . Thanks again.
    NewImprovedRon likes this.
  6. Jan 18, 2017 at 7:27 AM
    Ericsopa
    Glad you found it.
  7. Jan 18, 2017 at 7:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Water pump is a common leaking point in the tundra.
  8. Jan 18, 2017 at 7:41 AM
    Ericsopa
    Haha....so true! It's a common leaking point in about every vehicle I've ever seen.
