Losing antifreeze
Discussion in '2nd Gen Tundras (2007-2013)' started by rb8jm, Aug 27, 2022.
  1. Aug 27, 2022 at 6:35 PM
    rb8jm
    rb8jm [OP] New Member
    Just purchased 07 Tundra notice that the antifreeze reservoir was low on antifreeze. I filled the reservoir to the full line and drove about 50 miles. checked it again the next day and all the antifreeze I put in was gone. I see no sign of the leak on the ground or anywhere on the vehicle.
  2. Aug 27, 2022 at 8:28 PM
    05TacomaCO
    05TacomaCO t800_tundra
    Paul
    Pueblo West, CO
    2010 CM Platinum 4x4
    Toytec Boss 3" coilovers, AAL in rear with Eibach pro shocks, RCI skid, Method 701 Falken WIldpeak 285/75 R18. C4 Hybrid front bumper. SS3 fogs, Auxbeam 7” round off-road lights. Black Oak ditch lights. Smittybilt 10k winch. RCI Sliders. Toytec Shackles, Timbren Bumpstops.
    This happened on my Tacoma, never figured it out, traded in for my wife’s 4Runner, but I suspected a bad head gasket. You can get a test kit to determine if exhaust is coming through into your coolant.
  3. Aug 27, 2022 at 8:29 PM
    05TacomaCO
    Paul
    Pueblo West, CO
    I had signs of coolant being pushed out of the overflow. Yours may have just been low to start with.
  4. Aug 27, 2022 at 10:11 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    How many miles do you have on the truck? Check around the water pump area, there may be a small leak there
  5. Aug 28, 2022 at 1:21 AM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Lets stick with symplicity first, sounds like a bad thermostat that can no longer regulate the cooling system. When the system gets to max pressure the radiator cap opens to relieve the pressure and allows the fluid to go to the overflow bottle and out the overflow hose on the bottle creating a venturi effect sucking the fluid in the bottle out as the tube is relieving the system. Most times you can't see fluid as the tube usually goes down far enough so you can't see any fluid leaking. The rig should not overheat until most of the anti freeze is lost. I take it you are not overheating yet right? You could rig up a hose from the overflow to a bottle to see if the bottle catches fluid.
  6. Aug 28, 2022 at 6:43 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Just did mine recently
  7. Aug 28, 2022 at 6:51 AM
    Zolander
    Zolander New Member
    Zorro
    OffRoad
    Same thing happened with my tacoma but once I refilled it with new fluid, it hasnt happen ever since.
  8. Aug 31, 2022 at 7:35 AM
    minter66
    minter66 2007 TSS CrewMax
    Generally....it won't show on the ground if it is the typical water pump leak. Right after I bought my truck I noticed my coolant level kept getting low, but no puddle. It would basically get blown backwards by the engine/cooling fans and dry as a pink crust on the lower part of the engine.
    I'd check for white/pink crust - it is a very common problem with early 2nd gens.
