Loosening LCA Help
Discussion in 'Suspension' started by Lobodog1, Jul 22, 2020.
  1. Jul 22, 2020 at 6:34 AM
    Lobodog1
    Lobodog1 [OP] New Member
    Hello all,
    I am about to install some 6112's next week and have been researching the install. I did the lift on my 3rd gen 4runner and a friends 2nd gen taco but never had to loosen the LCA's to fit the coil-overs. I have searched everywhere to try and confirm which side of the LCA bolt/nut needs to be loosen to get them to swing down a bit. I have seen some say loosen the nuts facing the inside of the LCA, some say loosen the Cam bolts facing the outside, and some say the Cam bolts don't budge. I was hoping someone could point out exactly what needs to be loosen on the LCA to get them to swing down, maybe even with a picture so I don't waste an hour trying to figure it out. I appreciate any help on this, thanks!
  2. Jul 22, 2020 at 6:45 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    The nut preferably since there's less loosening torque to back it off, but I went after which ever nut/bolt side would spin. Mark both sides for reference then go ham. Did it for all 4. It doesn't really matter, just need the whole thru bolt to loosen so the LCA can swing down a bit. If neither nut/bolt side will loosen then you know you're gonna be SOL at your alignment anyways.
  3. Jul 22, 2020 at 2:15 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Loosen the ones facing forward on both. They are 24mm and torqued to around 207 ft lbs, that's probably why some people have a hard time to loosen. A breaker bar will help. And yes don't forget to mark them as a point of reference when you tighten back up. But you will still need alignment after. Good luck
  4. Jul 22, 2020 at 2:16 PM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Always loosen nuts first, less breakaway torque required to do so. Keep in mind even when you take the nut off, the bolt may be seized or the actual sleeve for the cam can get seized in the bushing as well. This is unfortunately common on Toyota 4x4's. This happened to me and i'm going to have to actually cut the bolts. Best of luck
