"Loose" Windows / Window Regulator
Discussion in '1st Gen Tundras (2000-2006)' started by jskeyes2, Jan 6, 2021.
  1. Jan 6, 2021 at 3:54 PM
    jskeyes2
    jskeyes2 [OP] New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    I have looked around on this topic, but not have found anything on point.
    My windows in my 2005 AC roll up and down fine, but when part way down, can wobble around some. I would like to drive with my windows cracked / slightly open, but I tend not to do because they move around too much for my taste.
    Is this something that is fixable / if so, how? Anything I have seen on window regulators has been due to broken windows or wont go up / down.
    Thanks.
    Darkness likes this.
  2. Jan 6, 2021 at 4:10 PM
    Professional Hand Model
    Hand Protectors
  3. Jan 6, 2021 at 4:18 PM
    jskeyes2
    Jeff
    Carlsbad, CA
    2005 Limited AC
    Thanks a lot. I guess it will make more sense when I dig in there, but is the whole point of drilling new holes is because the track has loosened up, and the way to fix it is push the track to the left, but in order to secure it since it moved from its original position is to drive those holes to get the bolts into it?
  4. Jan 6, 2021 at 4:44 PM
    Hand Protectors
    The bolts screw into the tracks. The new drilled holes allow a greater track tension once the track is pushed over/into glass and tightened.
