Loose, wandering feel on front end.
Discussion in 'Off-Topic Discussion' started by Redcon41318, May 14, 2021.
  1. May 14, 2021 at 6:31 PM
    Redcon41318
    Redcon41318 [OP] New Member
    Hey guys i acquired a 2006 2500 chevy. I took it out on its first 400 mile trip. Proud to say this 64k mile truck runs great drivetrain wise, but we all know these american truck needs some maintenance bc other things fall apart. Main thing i want to ask is front end, when driving highway speeds the front end seems to wander around a little if i were to make a minor move on the steering wheel. Feels just a little to loose for a “modern” 2006 model low mileage truck. I got new tires and got an alignment prior to this trip.
    i am thinking of replacing; tie rods, warned out bump stops and shocks? What else you suggest to remedy my issue?
  2. May 14, 2021 at 6:34 PM
    15whtrd
    15whtrd Mr. Blonde
    The guys at the alignment shop didn’t make any statements about worn parts? LCA bushings, tie rods etc?
  3. May 14, 2021 at 6:34 PM
    Redcon41318
    Check out
    The warned out bump stops, could this promote the unsteadiness feel along with warned tie rods, shocks?
    15whtrd likes this.
  4. May 14, 2021 at 6:37 PM
    Redcon41318
    Alignment shop said “oh front end never been aligned before tabs still on it, just a little toe in.” Looks good maybe ill go back since its so close by.
    15whtrd likes this.
  5. May 14, 2021 at 6:43 PM
    15whtrd
    15whtrd Mr. Blonde
    If the rest of the rubber looks like those bump stops, it’s a do! I know my buddies 95 Tahoe practically rides on the bump stops, so it could come in to play how it feels on the road. And those shocks are an easy swap out on those torsion bar front ends. That’s a pretty good looking 06 right there!
  6. May 14, 2021 at 6:44 PM
    15whtrd
    15whtrd Mr. Blonde
    You could definitely start with some new bump stops though LOL definitely needed.
  7. May 14, 2021 at 6:45 PM
    I'm betting thatbthe shocks are original. Definitely replace them as a start.
  8. May 14, 2021 at 6:47 PM
    Redcon41318
    Thanks guys, i just checked my tie rods ends, all busted, metal on metal.
    15whtrd likes this.
  9. May 14, 2021 at 6:48 PM
    15whtrd
    15whtrd Mr. Blonde
    Did you see those bump stops? LOL you can tell it just about rides on them until they blew out long ago.
  10. May 14, 2021 at 6:48 PM
    15whtrd
    15whtrd Mr. Blonde
    You’re due for all new rubber and joints. It’s low mileage but dried out.
  11. May 14, 2021 at 6:51 PM
    Redcon41318
    Yes! What you guys think definitely metal on metal?
  12. May 14, 2021 at 6:58 PM
    Yep....pretty bad.
    15whtrd[QUOTED] likes this.
  13. May 14, 2021 at 7:08 PM
    15whtrd
    15whtrd Mr. Blonde
    You can change those yourself! Just let the alignment shop readjust your alignment after you’re done with everything but you can get a pretty close by counting the threads.
    MS22 likes this.
  14. May 14, 2021 at 7:12 PM
    Redcon41318
    You guys think the warned tie rods outer, shocks and bumps the culprit for loose wandering feel?
  15. May 14, 2021 at 7:21 PM
    15whtrd
    15whtrd Mr. Blonde
    It really can’t hurt to start with those, they are consumable and look pretty dead. You can do all that yourself. When you put the tie rods back on, get it close to where the other ones were as far as thread count. (This way your alignment isn’t too far off) If that seems to have fixed the problem, go get another alignment and be done with it for a while. If not, guess we will have to go further in the suspension components like, lower control arm bushings ball joints etc.
  16. May 14, 2021 at 7:29 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    And worn is the word you’re looking for rather than warned. Worn out.
  17. May 14, 2021 at 7:35 PM
    Redcon41318
    Worned thanks!
  18. May 15, 2021 at 10:31 PM
    Redcon41318
    Is it possible that my wheels bearings are out too?
  19. Jun 24, 2021 at 6:57 PM
    Redcon41318
    Updated the dealership was
    Honest enough to drop roughly $5k in dealer/ mechanic fees
    On parts and labor to fix my wandering steering on my 2500 suburban! Check out
    The parts!
    drive review tmrw!
    steering gear box,
    Pitman arm, bracket, tie rods, ball joints, bilstein shocks and gosh.
    only if our dam tundras could handle a hefty toy hauler!
