Loose Mirrors 2006 Tundra Limited DC
Discussion in '1st Gen Builds (2000-2006)' started by tundrainsc, May 13, 2020.
  1. May 13, 2020 at 10:34 AM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    Both outside mirrors cabinets are loose and wobble slightly on the base. The screws are tight and I can't figure out a remedy. Next oil change I will ask Toyota dealer for estimate to fix. Anyone had this problem and have a fix?
  2. May 13, 2020 at 10:39 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    My mirrors on my Tacoma were worn out only fix I actually got to work was new ones from the dealer.
    aftermarkets were worse than the worn out oems and went back after the first test drive
  3. May 14, 2020 at 5:26 AM
    Professional Hand Model
    Hand Protectors
    Remove inside door panel and tighten the nuts where the mirror penetrates.
    NewImprovedRon likes this.
  4. May 14, 2020 at 7:02 AM
    tundrainsc
    06 Limited 4.7 2WD
    FIXED....well partly
    I was able to get most of the looseness out by removing the outer torx screw from the mirror housing and adding a washer. There is another screw in the housing closer to the door i could not get to with the torx tool. Here is a link that explains
    https://www.youtube.com/watch?v=RFugTZyYKMs
  5. May 14, 2020 at 7:06 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You can pop that cap off on the inside of the door like PHM said, but remove all the bolts, then you can pull the mirror off to tighten that inside screw
  6. Nov 9, 2023 at 5:49 AM
    rhalama
    rhalama New Member
    2001 tundra 4.7 auto
    Don't know if this is where I should post but my 2001 Tundra's passenger mirror is missing. The glass and I assume a plastic bracket. I ordered a glass from ebay, but thought the plastic bracket came with it---NOT----. Does anyone on this forum know where I can get the plastic bracket that attaches to the glass?
